Drag Radials with TPS
Old Jan 1, 2008 | 02:58 PM
54fighting's Avatar
54fighting
Default Drag Radials with TPS
I am planning to run drag radials at the track on a 2008 C6. When you reduce tire pressure down to 16-18psi, how will the TPS system react? Will it go into limp mode? Other issues?
Any help appreciated...thanks.
Old Jan 2, 2008 | 08:34 AM
avacorvette's Avatar
avacorvette
From: Canonsburg home of Yenko Chevy (gone but not forgotten) Western PA
I'd like to know also.
Old Jan 2, 2008 | 08:56 AM
Joe_G's Avatar
Joe_G
St. Jude Donor '08
I don't run TPS in my drag radials. I drive 80 miles up to the track, sometimes after 60 miles I get a DIC message to check rear pressure monitors, and they will read XX on the DIC. When that happens I cannot select Comp Mode - only Traction Control on or off.
Sometimes it doesn't trip the TPS message - there's no pattern that I can discern as I always drive the same route, sometimes it gives the message sometimes not. Overnight when I park in the garage it'll read the TPS in my street wheels if I leave the DR's on overnight. If you swap tires at the track you won't have any problem for sure, I do that with my road course tires and it always gets a reading back in the pits.
So long winded message to say just don't run TPS in your DR's and you'll be fine.
IMPORTANT - my car is an 05 built in May 05. Different years may react differently. If you do a search in the Autocross and Roadracing section you'll get some other owners checking in on this topic it's been discussed to death. Some guys build a can with the sensors in it and pressurize them and leave it in the cubby in the back! I don't have any problems the way I do things.
06C6FVR's Avatar
06C6FVR
It doesnt go into limp mode, but you will not be able to use the traction control system, (unless the tires are exactly the same height/diameter as stock)...If you leave the traction control on, it will always try to engage and wont drive right. Once off, it is fine. It will say something about either not having sensors or the tire pressure low, but you can clear that off the dic with the reset button. Drive on and Good luck!!
Old Jan 2, 2008 | 08:57 AM
6Speeder's Avatar
6Speeder
On my 07 Z06 when I lower the tire pressure below 24 PSI the tire warnings are displayed on the DIC everytime I start the engine and I have to hit reset multiple times before I can turn off the traction control. It never went into limp mode or had any other effect on the car's performance.
Old Jan 2, 2008 | 09:37 AM
54fighting's Avatar
54fighting
Joe,
Thanks for the input. I will be changing tires at the track, so if I leave the tires close enough to the vehicle, looks like it will pick up a reading?? Any idea on how long the reading will hold?
Think I will leave out the TPS sensors, change tires at the track and go from there?
Old Jan 2, 2008 | 09:54 AM
Joe_G's Avatar
Joe_G
St. Jude Donor '08
Originally Posted by 54fighting
Joe,
The reading will hold a long time, at least an hour I'd say. I say this because if I get the TPS message, it's usually an hour into my trip.
You will be just fine I'd say!
Old Jan 2, 2008 | 11:14 AM
bunk22's Avatar
bunk22
I drive 40 miles one way to the local track and my traction control usually kicks in after only a few miles with my DR's on. I just select it off and all is good. Like JoeG, I have an 05 model though, might react differently than your 08. BTW, so far, I've run my best mph to this point with 22-23psi. Any less, my mph falls, any higher, my car spins quite a bit.
Old Jan 2, 2008 | 11:56 AM
Joe_G's Avatar
Joe_G
St. Jude Donor '08
I've been having better luck lately with 18 lbs in my M/T DR's. Used to run 20 and more spinning, 18 seems to be good for traction.
I run mine on C5 fronts 8.5" so that might be part of the reason, my rims are technically too thin. I do note a little wobble at 125 at the top end at that pressure so I won't go lower.
Old Jan 2, 2008 | 12:20 PM
bunk22's Avatar
bunk22
Of course my driving sucks but my best 60-ft have both come with 18psi and 22psi...just the mph and ET were higher with 22psi. Maybe it was the conditions that day. My rims are off an old C4 Vette, ugly as **** but it gets the job done
Old Jan 2, 2008 | 12:37 PM
Joe_G's Avatar
Joe_G
St. Jude Donor '08
I find 18 to be much more consistent...as I think about it, I don't think I've spun at 2 different tracks since I went to 18. 22 was dicey for me, I'd spin if track prep was less than optimal.
It's 48 degrees as I type this in Miami Beach...coldest weather in 5 years....and the track is open tonight and my Drag Radials are mounted! Wish me luck buddy!!
Old Jan 2, 2008 | 01:07 PM
avacorvette
I went drag racing about a couple of months ago. It was about 50 degrees and I had bad wheel hop with my 07 and run flats on. I dropped the pressure to 24lbs and still had bad wheel hop. My best time was 13.4. I had to back off when I hit second gear all 3 times. So be carefull in cold weather wheel hop will break a rear. (cold tires = wheel hop)
Old Jan 2, 2008 | 06:13 PM
bunk22's Avatar
bunk22
Well good luck. Last time I ran, it was low 50's so cold for this area as well. Hoping to run at Panama City soon, I hear they hook better than any track around, it's all concrete.
To Drag Radials with TPS
