Checking compression
Old Jan 3, 2008 | 09:42 AM
aTX427
Guest
Posts: n/a
Default Checking compression
What is the best process for checking compression on the C6?
Old Jan 3, 2008 | 09:44 AM
C6~Missle's Avatar
C6~Missle
It's been awhile since I did this test.. but pull a spark plug and stick a compression tester gauge in the hole and crank it over...
Old Jan 3, 2008 | 11:09 AM
Michrider's Avatar
Michrider
The service manual says to remove all spark plugs, disable fuel sytem and ignition system. Hold throttle pedal wide open, and crank engine.
After at least 4 puffs on the gauge, that's the reading for that cylinder.
The manual says it should be between 100 and 150 and within 70% of each other. Generally on a healthy engine I will see 10% or less variation and probably around 120sh. psi.
The big thing to look for is the variation. If you've got 7 at 110 to
120sh and 1 at 70, that's leading to an issue in that one cylinder.
Old Jan 4, 2008 | 01:58 PM
Mike Francoeur's Avatar
Mike Francoeur
Disconnect the plugs from the fuel injectors - disconnect the wiring harness that clips into the coil packs - pull spark plugs and wires. Install compression gauge - turn over 3-4 times and right down your results. As michrider said, you're looking for a variation. Anything under 120 or so is rather low...
Old Jan 4, 2008 | 02:20 PM
eboggs_jkvl's Avatar
eboggs_jkvl
Moderator emeritus
2015 C7 of the Year Finalist
Try this...
http://www.ls2.com/boggs/torques/engcompress.htm
Elmer
Old Jan 4, 2008 | 02:47 PM
glenB's Avatar
glenB
St. Jude Donor '08-'09 & '12, '14
I C U R using a blower, R U having a blow-by problem ? If so, use a leak down tester.
To Checking compression
