rear diffuser
Old Jan 3, 2008 | 02:56 PM
yfzmotox21's Avatar
yfzmotox21
Default rear diffuser
does anyone offer an after market rear diffuser? i have seen some pics on the forum of some carbon fiber looking rear diffusers but was unable to find some on the net. Anyone know about any?
Old Jan 3, 2008 | 04:24 PM
NYC6's Avatar
NYC6
I think a rear diffuser in tested with the car in a wind tunnel to work as it should. If your buying something different for aestetic reasons then thats different.
ChargedC6's Avatar
ChargedC6
if i remember correctly east coast corvettes has the factory C6 difuser in carbon fiber.
Old Jan 3, 2008 | 04:26 PM
scottycards's Avatar
scottycards
St. Jude Donor '08 thru '13
The Lingenfelter one looks nice, particularly with the color-matched paint. It's on their site.
http://www.lingenfelter.com/store/ln-bk23.html
Old Jan 3, 2008 | 11:33 PM
TESTOSTERONE C6-R's Avatar
TESTOSTERONE C6-R
I remember coming across a yellow c6 "i belive from europe" that had a nice rear diffuser.
I might have to search for it again.
Old Jan 3, 2008 | 11:57 PM
XCELER8's Avatar
XCELER8
Its one full piece, I have one of there bumpers. See sig
Old Jan 4, 2008 | 01:22 PM
Gene Gorman's Avatar
Gene Gorman
Try West Coast Corvettes. They have a Carbon fiber one.
Old Jan 4, 2008 | 03:38 PM
John Shiels's Avatar
John Shiels
From: Buy USA products! Check the label! Employ Americans
that is not a diffuser it is a rear fascia
Old Jan 4, 2008 | 03:47 PM
scottycards
I'm well aware of what a diffuser is, and the channels on the rear fascia do serve to diffuse air as it exits from under the car.
Why someone would need a full-on diffuser, or even want to run one on a street car is beyond me, so I offered up the Ling. item. I've run in cars with diffusers, and they really only come into play at high speeds- much higher than any "normal" street car will see for a period of time that would necessitate the use of a diffuser.
200MPH- diffuser helps. Under 200- probably not necessary or much of an advantage in the C6, for most applications, thus my recommendation of the Ling. item. The stock "diffuser" should work just fine to keep the turbulence at the rear of the car manageable.
Old Jan 4, 2008 | 04:09 PM
John Shiels
Diffusers helps below 200 or even at and below 100 mph it makes the air exit faster with less turbulence under the car for a low pressure zone or down-force. There is no stock diffuser. There is a fascia with holes which lets air escape. I seriously doubt holes in a fascia straightens anything. Putting a diffuser on a Corvette with rear exiting exhaust would be near impossible. You also want the bottom of the car flat like a plate going to the diffuser. JMHO
Old Jan 4, 2008 | 04:11 PM
John Shiels
Old Jan 4, 2008 | 04:17 PM
scottycards
Good info, and I agree. I just wasn't sure the guy really wanted a true diffuser..........probably my bad, there.
We used to run one on our Unlimited car in Open Road Racing, and it really helped. But we didn't add it until the speeds got really high, so I'm not used to feeling a need for one until the numbers get big.
Old Jan 4, 2008 | 04:18 PM
SicMSP - Daniel's Avatar
0SicMSP - Daniel
Former Vendor
apsis - forum vendor
Old Jan 4, 2008 | 05:05 PM
John Shiels
I would put one on my track car but with rear exhaust I have no clue how to. I wanted to flatten the bottom of the car but the exhaust hangs down to far for me to plate it with some aluminum. I have some picture's of the real C6R diffuser when they were at Lime Rock. Early diffusers from GM had about 4-5 shall a say blades for lack of the proper term.
They newer ones have about a dozen blades. I was looking at my die-cast and noticed the difference. Figured the cheeped out. Then I looked at the old picture of C5R and seen it was Right. They never bother to change it on the C5R I guess for $$ purposes on a die-cast car. I'll try to post diffuser pictures later.
World Challenge C5R cars opened up the license plate area for better aero. I bought the SAE paper on the wind tunnel testing they did on Mc Clures car few years back and mine is basically the same.
Old Jan 4, 2008 | 05:26 PM
scottycards
When I think diffuser, I think race application only.
Here's a photo of the (I know, I know) Camaro we ran in the Open Road Racing events- decent shot of the diffuser- I lightened up the photo to view it on my poor work monitor, so it might come out a bit bright. 6 "blades". Worked great, so much so that the rear spoiler eventually was removed, and we got more top end due to less drag- the back end got real light, tho. Scary at 215...........
Car has side nascar-style exhaust.
Edit- this was right at launch- the front air dam would just drag on the ground when the car was standing still- hence the squat, and strange stance- and front end too high off the ground.
Old Jan 4, 2008 | 06:39 PM
John Shiels
fastest I have gone is 190.
Old Jun 13, 2009 | 10:50 PM
envyperformance's Avatar
envyperformance
1st Gear
Default Prototype Diffuser
I know this is an old post but here are some pics of a prototype diffuser in the works at Xtreme Motorsports in Florida from what I hear they are testing it at some HSR events and waiting on some wind tunnel time to get some real numbers on it.
http://motorsportsxtreme.com/slide_s...user/index.htm
To rear diffuser
Old Jun 14, 2009 | 12:41 AM
danl72's Avatar
danl72
Some of them look good and some do not.
Old Jun 14, 2009 | 01:25 AM
C6400hp's Avatar
C6400hp
From: DFW This user does not support or recommend the product or service displayed in the ad to the right
http://www.breathlessperformance.com...5-exterior.asp
Old Jun 14, 2009 | 07:33 AM
timd38's Avatar
timd38
Priced like a house.
