Header Install: Re-use stock gaskets??
Old Jan 3, 2008 | 03:45 PM
1.8t's Avatar
1.8t
Default Header Install: Re-use stock gaskets??
I will be performing a header install within the next couple of weeks. I know a lot of people say they re-use the stock ones, however, the ones that kooks don't seem that bad. I woud like to note that my car doesn't even have 4k miles on it yet, so the stock gaskets will be in great shape. What is the general consensus on this? Kooks gaskets or stock?
Old Jan 3, 2008 | 04:13 PM
welcome2try's Avatar
welcome2try
From: Objects in your mirror are losing , Long Island, NY
St. Jude Donor '08
After a year and a half my kooks gaskets blew, I replaced them with factory, steel layered exhaust manifold gaskets..much better than kooks..can be reused. Don't get cheap on this not worth it, order the factory ones from Gene Culley, for $27 bucks shipped cheap insurance..replaced mine last week.. Should have seen the kook ones fried Both sides went after 1.5 years..
Old Jan 3, 2008 | 04:16 PM
dkluko's Avatar
dkluko
I replaced my existing factory gaskets with new factory gaskets when I did my headers. Definitely worth spending 50 or so bucks for new ones if you're spending the $$$ on new headers.
Old Jan 3, 2008 | 04:17 PM
tloon's Avatar
tloon
I had 5000 on it last month when I did it with the Kooks. Everyone here says use the existing gaskets, so I did. No problems so far.
Old Jan 3, 2008 | 04:20 PM
Jorday's Avatar
Jorday
Yeah i'd use the stock gaskets again. I've been doing this on LSx motored cars for many years without a problem.
Old Jan 3, 2008 | 04:24 PM
vette05's Avatar
vette05
Use new stock gaskets. You won't be sorry later.
Old Jan 3, 2008 | 04:39 PM
Tony B4's Avatar
Tony B4
St. Jude Donor '08
Use new OEM gaskets.
Old Jan 3, 2008 | 04:52 PM
HawaiiC6's Avatar
HawaiiC6
Kooks header gaskets are only single layered the OEM gaskets are triple layered, there is a huge difference.
I am experimenting with a carbon fiber gasket, will see in time.
Old Jan 3, 2008 | 05:00 PM
Neumonic2002's Avatar
Neumonic2002
St. Jude Donor '09-'10
re-use the ones you have or buy new factory ones, either way you will be better off than the Kook's gaskets.
Old Jan 3, 2008 | 05:12 PM
C6 DVL's Avatar
C6 DVL
St. Jude Donor '08
use exhisting gaskets when I put on LG Headers @ 2,100 miles
Old Jan 3, 2008 | 05:15 PM
bunk22's Avatar
bunk22
My Kooks gaskets started leaking after a year. Replaced them with OEM stock gaskets.
Old Jan 3, 2008 | 05:35 PM
lemans 07's Avatar
lemans 07
re-use the factory gaskets. Done it on the last 2 vettes I did. The $$$ saved went to the celebration beer fund.
After looking at the gasket, it appears you could reuse it as many times as you want. It works like a mechanical seal and requires no silicone or anything to seal properly.
Old Jan 3, 2008 | 05:55 PM
welcome2try
St. Jude Donor '08
Wow all 11 posts say go back to factory..Get the point?..Good luck..
Old Jan 3, 2008 | 06:25 PM
Mike V.'s Avatar
Mike V.
Default Too late now what?
I just did mine & the CF article posted from Vette mag on Kooks install said to use the new gaskets supplied by Kooks. Which is what I did, it would appear the concensus would be otherwise. That said, would you go to the trouble of changing them out. If I choose to change them out, can it be done w/o loosening the collectors from the cat/x-pipes, but rather just pulling the bolts at the heads? They also gave torque specs, can you get one in there to all the bolts. I also have saw a fair amount of comments about reusing the stock bolts vs the ones supplied by Kooks which are shorter I assumed b/c the header flanges aren't as thick as the manifolds. Any thoughts here?
Old Jan 3, 2008 | 06:48 PM
1.8t's Avatar
1.8t
Factory it is
Old Jan 3, 2008 | 08:48 PM
SSRogers's Avatar
SSRogers
Wow, Glad I saw this tread.
Old Jan 3, 2008 | 09:05 PM
toro1966's Avatar
toro1966
Yes, you can remove the bolts and use a jack stand to balance the header. Then you can swap out the gaskets. I think a stock set cost me 35 bucks. I would switch them, just to avoid issues in the future.
Cheers.
To Header Install: Re-use stock gaskets??
Old Jan 3, 2008 | 09:28 PM
TEXASRANGER's Avatar
TEXASRANGER
HOOK-EM HORNS
St. Jude Donor '08
Old Jan 3, 2008 | 11:02 PM
GlenM's Avatar
GlenM
I just did my kooks install over New Years. Want some really good advice?
USE THE GM GASKET!!!! I thought the .062 thick gasket from Kooks was really trick and ignored all the forum advice and used it. Immediate leak as soon as I started the Vette. Sounds like a bad lifter, real metallic sound.
Screwed around for two hours - different torque and tightening sequence.
The thicker Kooks gasket isn't compliant enough to correct any out of flat condition in the header flange. I could always fit a .003 feeler blade in between the header gasket from Kooks and the flange. Changed out to the used GM gasket and NO PROBLEMS. It was the only hitch I had in my otherwise excellent Kooks header experience.
Old Jan 3, 2008 | 11:50 PM
Super4x4Duty's Avatar
Super4x4Duty
I'm hard headed and used the Kooks supplied gaskets just because everyone has had problems with them. Don't do it. After just a few miles these things started leaking like crazy.
George, start sending GM gaskets with your headers. These gaskets you're sending with your headers aren't worth a darn.
