heater messed all up
Old Jan 5, 2008 | 08:30 PM
c-6vette's Avatar
c-6vette
5th Gear
Default heater messed all up
the passengers side hvac controls work right but the drivers side is stuck on cool what do i do
Old Jan 5, 2008 | 08:34 PM
johnodrake's Avatar
johnodrake
Moderator
Sounds to me like the vent door is stuck. From what I understand, that is not an easy fix. Hopefully, I am wrong and the fix will be simple.
Old Jan 5, 2008 | 08:57 PM
calemasters's Avatar
calemasters
If your referring to the control head, it may need to be replaced. But 1st disconnect the negative battery cable for 60 seconds and reconnect to see if the control resumes normal operation.
Old Jan 5, 2008 | 11:25 PM
knkali's Avatar
knkali
Or pull the fuse for the heat/air unit and try resetting that way
Old Jan 6, 2008 | 12:02 PM
c-6vette's Avatar
c-6vette
5th Gear
has anyone else heard or anyone else having this problem
To heater messed all up
