Granatelli Mass Airflor Sensor MAF
Old Jan 9, 2008 | 10:16 AM
07CSicks's Avatar
07CSicks
Default Granatelli Mass Airflor Sensor MAF
Has anyone installed one and found any of the below information to hold true??? I'm interested, but I trust you all more than manufacturer info.
Thanks!
Improves mileage and throttle response. This Mass Air Flow Sensor is chassis dyno proven to add 8-25 horsepower (depending on application), with a 60% airflow increase over stock. Improves performance from 2,000 rpm to red line. "Truly Calibrated" on Granatelli’s in-house MAF dyno and flow bench to optimize performance for your specific application. Compatible with most electronics and aftermarket bolt-on performance equipment. This direct OEM replacement won't void your factory warranty. Installs in 10-15 minutes using basic hand tools.
Old Jan 9, 2008 | 10:38 AM
EuroRod's Avatar
EuroRod
Useless. Period. Save your money for a real performance upgrade.
Old Jan 9, 2008 | 10:49 AM
C6~Missle's Avatar
C6~Missle
I agree with the above on a stock setup.. I doubt the MAF is a bottleneck under 500HP
Old Jan 9, 2008 | 11:00 AM
vettl83's Avatar
vettl83
My brothers 07 modded to 507 rwhp uses the stock maf with no issues and I use the stock maf on my 07 with a Maggie set up, no issues.
Old Jan 9, 2008 | 11:02 AM
andreas g.'s Avatar
andreas g.
He sells snake oil. His products do nothing but empty your pocket.
Run don't walk from anything he sells.
Old Jan 9, 2008 | 11:32 AM
07CSicks's Avatar
07CSicks
That was my hunch..
Thanks for the advice....
Maybe if I spilt the $400 it would have cost I could get you all a tank of gas... That would be better used than the MAF!!!
Old Jan 9, 2008 | 11:34 AM
6spdC6's Avatar
6spdC6
Active Streak: 90 Days
From: Northern NYs Adirondack Mountains,http://www.visitsacandaga.com.
I have never heard anything good about Granatelli’s MAF.
Old Jan 9, 2008 | 11:50 AM
vettl83's Avatar
vettl83
Originally Posted by 07CSicks
That was my hunch..
I think you would be better off having Cory at LS2 Portworks port your stock intake and throttle body for about the same money.
Old Jan 9, 2008 | 12:24 PM
06.Z51.MontRed.Vert's Avatar
06.Z51.MontRed.Vert
From: Eastern PA:ECS Paxton Novi 1500(676rwhp,585tq on stock engine),LG headers, 410's, Corsa Sports, ECS Alky Kit
St. Jude Donor '08-'09
8-25hp How can they get away with even saying that, what a crock-o-shat!! I dont think even the TurboNator people are that bold..
Old Jan 9, 2008 | 12:49 PM
andreas g.'s Avatar
andreas g.
If I'm not mistaken, just a little while ago, he stated his ignitions wires were worth and I quote", Adds true, dyno proven 12hp gain, can add up to 15hp(normally aspirated) & 35hp ( s/c, turbo, notous )" This was in the GM high tech mag, march 2007 page 65. I now wonder why were modding with heads and cams when all we really need to do is just put some Granatelli 0 ohms wires on......
Old Jan 9, 2008 | 02:08 PM
HawaiiC6's Avatar
HawaiiC6
Thanks!
Wow, I put on a Granatelli MAF and gain 25 hp, for 10-15 minutes of work. If someone takes 10-15 minutes to change out a MAF then they deserve to run a Grantelli MAF
You want throttle response, get yourself a ported throttle body you will feel a night and day difference in throttle response.
Old Jan 9, 2008 | 02:27 PM
dennis50nj's Avatar
dennis50nj
Old Jan 9, 2008 | 02:36 PM
Silverspeed's Avatar
Silverspeed
St. Jude Donor '13, '15
Outrageous claims. 8-25hp from a MAF???? That would indicate a minimum of 8 hp on a stock motor. NO WAY that is happening.
Old Jan 9, 2008 | 03:22 PM
Ragtop 99's Avatar
Ragtop 99
The increase in airflow isn't worth anything on a basically stock motor. The MAF may increase HP on a stock motor because the GMAF calibration is different from the stock MAF and leans the motor out. With the LS3s seemingly running rich from the factory it could actually work.
So why don't you want one? The answer is the GMAF is band-aid for a good tune. In the dark ages before tuning software, fudging the MAF was one of the few solutions available for a tuning a car that was rich. Today, you can put your money into a good tune or purchase HPT and do a proper job of tuning the car.
Now you know why you need to run away fast from this.
Old Jan 9, 2008 | 05:07 PM
666vette's Avatar
666vette
Get your throttle body and intake ported instead.
Old Jan 9, 2008 | 06:24 PM
HawaiiC6's Avatar
HawaiiC6
, my ported intake just got in yesterday, will have a fun afternoon doing the install today after I get home from work.
Old Jan 9, 2008 | 08:59 PM
JIM07's Avatar
JIM07
I'm already starting to feel the HEAT!!!
I had a 99 trans am that I spent many days at the track with and at least 200 1/4 mile passes. I ran some bracket races and was able to run consistant 12.60s -70s at 105-106 mph. One night a friend had a Granny MAF on his T/A and knew I had run several consistant run that night and asked if I wanted to try his MAF. I was not a believer but gave it a shot. I ran three hot passes within 10 minutes of each other and every run was a 12.60s at 108s MPH. I had never run 108s before so I became a semi believe!!!! I bought one the next day. Just my experience guys!!!! Do I have one on my 07 vette?? No
To Granatelli Mass Airflor Sensor MAF
Old Jan 9, 2008 | 09:45 PM
CodyC6's Avatar
CodyC6
I can't say they don't work until someone actually tests one and shows no gains.
Old Jan 9, 2008 | 09:58 PM
burtonbl103's Avatar
burtonbl103
St. Jude Donor '06-'07-'08,'12-'13
Snake Oil
Old Jan 10, 2008 | 08:11 AM
ken-rx's Avatar
ken-rx
