spark plug wires
Jan 9, 2008 | 02:50 PM
spark plug wires
how do you remove the spark plug wires on the plug end of an ls 2 ?
Jan 9, 2008 | 03:11 PM
just wiggle back and fourth and then pull
Jan 9, 2008 | 04:05 PM
From: stafford country, va. Avatar: Me on turn 3 @ Bristol (The World's Fastest Half-Mile)
Quote:
Originally Posted by
dennis50nj
although, i would add..... cut the metal shield off, grab the boot with a firm hold and pullllllllll.
sorry, just having fun.
Jan 9, 2008 | 05:07 PM
so the metal sheild needs to be removed ?
Jan 9, 2008 | 05:21 PM
hucktyson
no he he was joking
don't cut the shied off grab the shield and wiggle is and pull it and the wire and shied come off as a unit
Jan 9, 2008 | 05:32 PM
St. Jude Donor '21 thru '26
dennis50nj
no he he was joking
Dennis what does your license plate say?? Leif
Jan 9, 2008 | 05:39 PM
cleif2000
fastest bolt/on 11.14 did you see the video
Jan 9, 2008 | 05:45 PM
dennis50nj
Yes I did see your run it was an awesome run. What does your license plate say SHP 80L can't figure it out. Leif
Jan 9, 2008 | 05:59 PM
cleif2000
i don't know. its just the plain plate random sequence, it looks like it should be something but i cant figure it out either
Jan 9, 2008 | 06:22 PM
Put a little dielectric grease on them when you put them back on.
Jan 9, 2008 | 11:21 PM
dennis50nj
That's funny! My Plate is PRIAPSM (if you don't know wiki it) but the reason for my reply, I had a friend get ILV-269 by luck of the draw! How's that for a random plate!
Jan 10, 2008 | 08:27 AM
Mike Villareale
Jan 10, 2008 | 09:06 AM
dennis50nj
no he he was joking
although i didn't use them when i replaced my wires.
Jan 10, 2008 | 09:31 AM
think the weight loss helped
i was going to but it seemed like it help for removing the wires
Jan 10, 2008 | 09:36 AM
dennis50nj
but, of course.....
every little bit...
dennis50nj
i found it was actually harder on the boot (when removing/disconnecting the wires) with the 'metal heat shield' in place. but then again, how often does one really need to
play with his wires.
ps. what gap are you running?
Reason: add ps.
Jan 10, 2008 | 11:17 AM
Cruising
I just installed Champion Ididiums at .055 with MSD 8.5 red wires and it runs great.
