Is this normal price for this mod?
Old Jan 9, 2008 | 09:50 PM
Red Sleeper's Avatar
Red Sleeper
Default Is this normal price for this mod?
I have a quote to have a performance gear installed in my '06 A6.
The quote includes remove and replace differential, remove Torque management and calibrate speedometer and nothing more.
The price is $3065. Is this price HIGH - LOW - ON THE MONEY?
Old Jan 9, 2008 | 09:53 PM
C6 DVL's Avatar
C6 DVL
St. Jude Donor '08
it's high
if it doesnt include harden output shafts (2), then the price is very very very high
Old Jan 9, 2008 | 09:59 PM
dennis50nj's Avatar
dennis50nj
over a grand to high
Old Jan 9, 2008 | 10:11 PM
Red Sleeper
Originally Posted by C6 DVL
it's high
It doesn't have hardened shafts but is supposed to be cryo treated and micro polished.
Old Jan 9, 2008 | 10:27 PM
johnodrake's Avatar
johnodrake
Moderator
Sounds high to me - who is it from?
Old Jan 9, 2008 | 10:29 PM
Fore58's Avatar
Fore58
Stall converter included?
Old Jan 9, 2008 | 11:25 PM
Red Sleeper
I would rather not say but I can say that he is not a supporting tuner.
It's a long story but to keep it short. I have known this guy for a long time and call him a friend. He knows I feel his price is high. I also know he reads these posts.
Old Jan 9, 2008 | 11:26 PM
Red Sleeper
Nope!
Old Jan 9, 2008 | 11:48 PM
ekim81's Avatar
ekim81
i think supporting tuners offer for ~$2k... check out MTI or Vengeance, since you're in GA. i haven't yet taken my car to either of them, but i've heard many good things about both.
Old Jan 10, 2008 | 06:41 AM
Hooked4Life's Avatar
Hooked4Life
You should consider doing the install yourself, or just get a quote on labor. I went this route, and went through Chuck CoW, and saved a bunch, and got hardened shafts.
Old Jan 10, 2008 | 07:37 AM
TEXASRANGER's Avatar
TEXASRANGER
HOOK-EM HORNS
St. Jude Donor '08
I see them going for $1599 from forum vendors. Installed.
Old Jan 10, 2008 | 09:59 AM
dennis50nj's Avatar
dennis50nj
300 more for the hardened out put shaft
Old Jan 10, 2008 | 10:08 AM
johnodrake's Avatar
johnodrake
Moderator
Check out DTE for comparison:
http://www.dtepowertrain.com/dte_c6_diff.htm
DTE Stage 4 Street Performer Plus Extreme
Standard HP upgrade package
DTE engineered 4340m-300M hardened steel left output shaft
DTE engineered 4340m-300M hardened steel right output shaft
DTE engineered HD clutch pack pre-load spring upgrade
DTE engineered needle bearing axle support upgrade
DTE engineered internal carrier oiling modification upgrade
DTE engineered HD 6061-T6 billet aluminum pinion shaft support upgrade
DTE engineered pinion drive to accept the LG Motorsports Differential Cooler Kit as a bolt-on later, if chosen
Exchange or build your supplied core & includes lubricants: $2399
Turn-key installation M6/M12 and includes lubricants: $2799
Turn-key installation A4 & includes lubricants w/ custom PCM shift point calibration: $2899
Old Jan 10, 2008 | 10:17 AM
jmudreamvette's Avatar
jmudreamvette
He is a friend? There are better prices out there....
Old Jan 10, 2008 | 11:05 AM
Red Sleeper
I talked to Chuck earlier via PM but didn't talk money. I didn't want to drive that far for him to do the install. I don't know if my nerves can handle driving that close to NY City anyway but I do like CoW and I wish he was closer.
From all the rest of the super people that have chimed in I see I need to do some more checking.
Old Jan 10, 2008 | 11:23 AM
Red Sleeper
He owns a speed shop with a dyno and somewhere along the line we became friends. I have done a little dyno tuning for him for some of his customers with C4's. I'm a fair tuner when it comes to C4's but not a pro by any means. I have never charged him a penny for my services and it actually cost me money because the drive to his place from mine is nearly 100 miles. I can't understand why he won't return the favor. Oh well it takes satisfied customers to build a business.
Old Jan 10, 2008 | 11:27 AM
Red Sleeper
There is a member in our Corvette club that uses MTI and likes them very well. One of the MTI team put me out in the last race during out show and drag event. He took first and I took second. I think I need to go talk to them.
To Is this normal price for this mod?
Old Jan 10, 2008 | 12:22 PM
Chuck CoW's Avatar
0Chuck CoW
Former Vendor
St. Jude Donor '07-'08-'09-'10-'12-'13-'14
Default This is actually MY price.
The price is $$2,499. Is this price HIGH - LOW - ON THE MONEY?
Our diffs are built and INCLUDE THE DRIVER HARDENED AXLE SHAFT. Not the weaker late model shaft some "claim" is hardened, but ours is truly 300M material which is very difficult to get. 4340 STEEL AXLES ARE NOT 300M. They are weaker. Don't be fooled. Each of our gearsets is REM polished to run in absolute silence. Additionally, most new A6 diffs are built with the "optional" STRONGER side covers WITH the oil cooler ports to make it very easy to upgrade to the cooler or pump later.
We also have the lowest CORE CHARGE in the business! There's no reason to lay out over $2,000. for a core charge...
We TRUST you!
When you want the best rear end, with the most features...Give us a call.
Call me any time to find out more.
Chuck CoW
Old Jan 10, 2008 | 01:49 PM
Ted P's Avatar
Ted P
Mike Straightline quoted me around $1500 (no tune) for the 3:15 gears. He is a forum vendor
Old Jan 10, 2008 | 02:06 PM
07CSicks's Avatar
07CSicks
Time for you to shop around... With the money you save you can take your "friend" to a very nice meal...
