390 gears how fast
Old Jan 10, 2008 | 08:56 AM
dennis50nj's Avatar
dennis50nj
Default 390 gears how fast
i have been thinking about a gear chance, 1 have till march to decide, thats when the track opens again.
Old Jan 10, 2008 | 09:02 AM
ekim81's Avatar
ekim81
didn't members of this board overwhelmingly vote for 4.1 over 3.9 gears? (ref: see thread started by "c6 dvl").
Old Jan 10, 2008 | 09:09 AM
11sec_lx's Avatar
11sec_lx
Yea, but not for an A4.
Old Jan 10, 2008 | 09:12 AM
dennis50nj's Avatar
dennis50nj
yes, thats why im asking
Old Jan 10, 2008 | 09:13 AM
ekim81's Avatar
ekim81
oops... my mistake.
Old Jan 10, 2008 | 01:02 PM
SpinMonster's Avatar
SpinMonster
Hey Super D, what gears you got now playa?
Old Jan 10, 2008 | 04:53 PM
dennis50nj's Avatar
dennis50nj
hey Spin, i got the 373s. i got a lot of questions i wonder what my top speed is now and what it would be with the 390s
Old Jan 10, 2008 | 05:52 PM
gfreeman's Avatar
gfreeman
I had 4.10s and found them TOO Deep, made 1st gear useless at WOT w/ excessive wheelspin. On OEM tires at 30PSI and with 386RWHP 3.73s hook up! With either gears I found no appreciable difference in freeway gas mileage.
Old Jan 10, 2008 | 07:20 PM
3 Z06ZR1's Avatar
3 Z06ZR1
Is your's a MN-6?
Old Jan 10, 2008 | 07:25 PM
dennis50nj's Avatar
dennis50nj
Originally Posted by Rock'n Blue 08
Is your's a MN-6?
nay its an a4
Old Jan 10, 2008 | 07:48 PM
LS1LT1's Avatar
LS1LT1
I vote no on the 3.90s...though if it was still back when ya had 3.15s and you were trying to decide between 3.73s and 3.90s then I might say go 3.90s because they work and it's not a 100 miles a day daily driver. Ellis has 3.90s and they're fine for weekend use and driving to/from the track. But for now I wouldn't get rid of those 3.73s, it really is the PERFECT gear for a street driven A4 car.
Also keep in mind that your final gearing is actually slightly higher than 3.73 as it is because your tires are 26.13" (295x35x18 BFGs) tall as opposed to 26.85" (stock) as well so that helps, in theory you might have a 3.80 rear in there. A lower overall diameter tire such as the 275x40x17s or 255x50x16s (both somewhere between 25.7" and 26.1") would give ya even more gear so to speak.
You might also consider a higher stall converter as well.
Old Jan 10, 2008 | 08:36 PM
Ragtop 99's Avatar
Ragtop 99
gains from 3.73s to 3.90s are going to be small. In the F-body world, A4s switching from 3.73s to 4.10s saw less than a .1 increase, frequently just .05. The only time I saw guys get more was when they went to a bigger tire as part of the switch and got a better hole shot out of it.
I agree with LS1LT1. If your stall is less than a 4000, that could be an area for big improvement.
Old Jan 10, 2008 | 08:46 PM
jschindler's Avatar
jschindler
I admit to not being an expert on automatics, but I still am willing on venturing an opinion. If you already have a high stall converter, I don't see the lower gears doing much good. You are already getting a ton of torque to the rear tires via the torque converter, and your high stall is putting you in the meat of the powerband the instant you take your foot off the brake and leave the line. So what is lower gears going to add?
Old Jan 10, 2008 | 08:52 PM
oneblackvette's Avatar
oneblackvette
I had 3:90's in my 2005 A4 and it was a bit much for daily driver.
Old Jan 10, 2008 | 09:25 PM
LS1LT1's Avatar
LS1LT1
Well there is no doubt that going to 3.90s or better yet 4.10s will improve Dennis's ETs if he's on a tire that will hold/hook it well, and that's a big if. But at what price (stength/long highway trips/fuel economy etc.)?
The increased gearing will mean even more if he were to ever go with a cam or heads and cam but again only if the tires hold.
The one area where it could get questionable is with the traps and what gear the car will be crossing the line in (3 or OD?), this also will depend on tire heights chosen.
Old Jan 10, 2008 | 10:12 PM
dennis50nj's Avatar
dennis50nj
i wonder what the top mph would be for roll racing
Old Jan 10, 2008 | 10:32 PM
SpinMonster
I know what you need is .15 on your ET so it may work.
To 390 gears how fast
Old Jan 10, 2008 | 11:36 PM
Tommy D's Avatar
Tommy D
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16
St. Jude donor in memory of jpee '14
If you are only looking for that extra .15...... as Marc has already stated ....... "A lower overall diameter tire such as the 275x40x17s or 255x50x16s (both somewhere between 25.7" and 26.1") would give ya even more gear so to speak".
A quick, dirty & cheap way to do it
Old Jan 11, 2008 | 03:13 AM
jklarkpimp's Avatar
jklarkpimp
i have an a4 with 373 gears, 1st to 2nd shifts at 60mph, 2nd to 3rd at 90 ,3rd to 4th at 120, 4th to redline 150-160
i dont give a damn about top speed, ill never drive 150
0-150 really fast
Old Jan 11, 2008 | 05:06 AM
Joe_G's Avatar
Joe_G
St. Jude Donor '08
I'd go the shorter tire route. M/T 17 drag radials will give you more or less the effect of 3.90's at a MUCH lower cost and they hook like crazy.
IMHO 3.73 to 3.90 is too small a difference to warrant the high price of a diff change. You could spend the money on a cam instead and get a much greater gain. And don't forget the sound of the cam.
