guys with maggies step inside
Old Jan 11, 2008 | 03:22 PM
FaSStC5's Avatar
FaSStC5
Default guys with maggies step inside
looking to get a maggie for my C6 what RWHP did u guys get on stock motor plus full exhaust?
Old Jan 11, 2008 | 03:52 PM
Bushong572's Avatar
Bushong572
With a m112, headers and a 3.0" pulley, you will see 6-7 lbs of boost and (around) 500 rwhp/ 500 rwtq. If you run the stock 3.4" pulley with headers, you will make less then 5 lbs of boost. From what I've seen and heard, I would not run smaller then a 3.0 on the Magnuson 112......if you want more boost or power, I would buy the M122. The new larger m122 will make more power, maybe a owner will post (there's very few out there).
Old Jan 11, 2008 | 04:10 PM
FaSStC5's Avatar
FaSStC5
what size pullie does it come with??
Old Jan 11, 2008 | 04:37 PM
vettl83's Avatar
vettl83
3.4 stock, 3.2 for high altitude, and 3.0 and smaller are available from Reichard Racing.
Old Jan 11, 2008 | 04:44 PM
LS2-Zomb!e's Avatar
LS2-Zomb!e
a friend of mine is making 520rwhp from m112.. from 5 psi
Old Jan 11, 2008 | 05:12 PM
Bushong572's Avatar
Bushong572
Hi Dashti,
I've never heard of any maggie m112 LS2 car making those numbers with just headers at 5 psi.......
Old Jan 11, 2008 | 05:43 PM
FaSStC5's Avatar
FaSStC5
So Lets Say I Get A Maggie With Full Exhaust Would I Have To Get The Smaller Pullie?
Old Jan 11, 2008 | 05:52 PM
Bushong572's Avatar
Bushong572
No, you don't have to change the pulley. You will only see 4-5 lbs of boost if you run headers though.
Old Jan 11, 2008 | 06:17 PM
FaSStC5's Avatar
FaSStC5
if i wanna see 6-7 lbs then i would have to chage it right?
Old Jan 11, 2008 | 06:37 PM
Bushong572's Avatar
Bushong572
Yes, to a 3.0".
Old Jan 11, 2008 | 06:55 PM
FaSStC5's Avatar
FaSStC5
sounds good i think thats what im going to, does it whine loud???
Old Jan 13, 2008 | 11:03 AM
Gene Gorman's Avatar
Gene Gorman
I have a Maggie 122 with a comp cam and Dynatec 1 7/8 headers. We changed the 122s stock 3.6 pulley to a 3.2 pulley. It makes 7.5 lbs. of boost and 585 rwhp. The 122 is .800" longer so you will have to modify the rear cross member of a RK Sport hood to clear its extra length. The 122 is a full 2 liters so it does flow more air at lower temps. and in so doing produces more hp. I have had mine for over a year now and have had no problems with it other than I have no traction until 4th gear even with 345 PS2s. That said I would do it again this combo is so much fun to drive. It drives almost like a stock Corvette and gets great milage until you hit it then hold on because all hell breaks loose.
[IMG][/IMG]
[IMG][/IMG]
Old Jan 13, 2008 | 11:06 AM
Gene Gorman
Yes but only when you jump on it, otherwise you can't hear it.
To guys with maggies step inside
