C6 Electrical - GM Bulletin ref: RCDLR software
Old Jan 16, 2008 | 03:56 PM
1962 corvette's Avatar
1962 corvette
Default C6 Electrical - GM Bulletin ref: RCDLR software
My 2007 C6 'Z' is sitting at a local dealers shop pending a replacement Remote Control Door Lock Receiver (RCDLR) due to a software problem encountered when the dealer attempted to download software from GM supplier.
The car is imobilized - awaiting the component. Has anybody experienced this issue. The download is designed to eliminate battery drain problems (DBS).
Bill
Old Jan 16, 2008 | 07:28 PM
calemasters's Avatar
calemasters
Did the dealer pull the radio and HVAC fuse like the bulletin reads before they starting the download?
Can they do a nation wide dealer inventory search for the RCDLR? Did they open a **** case?
Old Jan 16, 2008 | 08:16 PM
1962 corvette
I will ask - do you have a copy of the Bulletin? or a copy of the instructions - I'v not seen the content
There is one in the nation (TX) - and they have put the ubit into thei9r **** Case' -
Old Jan 16, 2008 | 09:14 PM
calemasters
Document ID# 1927847
2007 Chevrolet Corvette
Subject: Dead Battery, No Crank/No Start (Reprogram Remote Control Door Lock Receiver (RCDLR) #07-06-03-001B - (03/21/2007)
Models: 2005-2007 Cadillac XLR (Including XLV-V)
2005-2007 Chevrolet Corvette (Including Z06)
Built Prior to the Following VIN Breakpoints:
This bulletin is being revised to update the correction information. Please discard Corporate Bulletin Number 07-06-03-001A (Section 06 -- Engine/Propulsion System).
Model
VIN Breakpoint
XLR
75600571
Corvette
75112132
Condition
Some customers may comment on a dead battery after the vehicle has been parked for a extended period of time. Typically, the battery will last approximately two weeks, depending on the initial state of battery charge.
Cause
A software anomaly within the remote control door lock receiver (RCDLR) causes an additional 30 mA draw on the battery when passive locking is enabled and the vehicle is parked.
Correction
Do This
Don't Do This
Reprogram the RCDLR.
DO NOT replace the RCDLR.
Important: Use the Pass-Thru method when programming and select "Replace and Reprogram ECU."
A new calibration has been released to correct this condition. Reprogram the RCDLR using SPS. This new service calibration is available on TIS2WEB.
Important: On Corvette models, prior to reprogramming, remove the Radio/S-Band/VICS 15-amp fuse and the HVAC/PWR SND 10-amp fuse from the I/P electrical center (passenger floor). Also, the ignition must be in the "Key On Engine Off" mode.
If the programming does not finish successfully and the RCDLR appears to be in a "locked-up" state, DO NOT turn off the ignition, it can be reset by removing the RCDLR fuse (#11 in the UBEC) for at least 30 seconds and reinstalling it. If the ignition was turned to OFF after the "locked up" condition occurred, its possible to continue programming by adding the VIN manually in TIS.
Tip
Transmitter programming and tire pressure learn procedures are NOT necessary after this reprogram.
Please refer to SI for additional information on other potential causes of battery drain.
Warranty Information
For vehicles repaired under warranty, use:
Labor Operation
Description
Labor Time
R9723*
Remote Control Door Lock Receiver -- Reprogramming with SPS
0.4 hr
* This is a unique labor operation number for bulletin use only. This number will not be published in the Labor Time Guide.
GM bulletins are intended for use by professional technicians, NOT a "do-it-yourselfer". They are written to inform these technicians of conditions that may occur on some vehicles, or to provide information that could assist in the proper service of a vehicle. Properly trained technicians have the equipment, tools, safety instructions, and know-how to do a job properly and safely. If a condition is described, DO NOT assume that the bulletin applies to your vehicle, or that your vehicle will have that condition. See your GM dealer for information on whether your vehicle may benefit from the information.
WE SUPPORT VOLUNTARY TECHNICIAN CERTIFICATION
© Copyright General Motors Corporation. All Rights Reserved.
Old Sep 14, 2011 | 12:49 PM
jmarin260's Avatar
jmarin260
2nd Gear
I can not turn off the fog lights,tail lights,side lights when i turn on the Corvette C6.Someone did this happen?
Old Sep 15, 2011 | 07:38 PM
erikszr1's Avatar
erikszr1
what.............
To C6 Electrical - GM Bulletin ref: RCDLR software
