05 horn help
Old Jan 19, 2008 | 11:01 PM
ChargedC6's Avatar
ChargedC6
Default 05 horn help
so i noticed since my magnacharger install my horn hasnt been working. does anyone know where the location of the stock horn is? i had a quick look under the car today and couldnt see i have searched and turned up nothing on here yet. so if anyone could point me in the right direction that would be awesome thanks!~
Old Jan 20, 2008 | 02:48 PM
ChargedC6's Avatar
ChargedC6
come on no body knows?
Old Jan 20, 2008 | 03:54 PM
pontnewynyddboy's Avatar
pontnewynyddboy
To get to the horn you have to remove the right front wheelhouse extension panel (taken from my helms service manual). you will have to raise the front of the vehicle to access this panel and remove the two small screws.Once removed the horn is bolted onto the skid bar.Hope this helps.
I should add this info is for an 07 c6 should be the same though.
Old Jan 20, 2008 | 04:05 PM
ChargedC6's Avatar
ChargedC6
you are the man thank you!
To 05 horn help
