Brake Question.......Just for looks
Has anyone tried to add just the rear Z06 brakes with stock Z51 front brakes?
Just trying to fill the wheel opening without going full big brake kit.
Was considering just all Z06 brakes, but I have 18x8.5 front wheels and they don't seem to clear.
Thoughts?
Brake Bias
Another way to get more overall braking grip is adding back some rear brake bias. The stock GM system is tuned for safety and not for lap times. This means they add a LOT of front bias because having the rear lock first is a dangerous situation to say the least and they would have lawsuits on their hands. The Brembo adds back some of the rear bias GM takes out. This means you'll be applying more brake force to the rear tires while the front is applying the same. This also translates to more brake grip and shorter stopping distance. Also the more rear brake bias and less weight tranfer allows you to trail brake into corners.
Brake Bias
If you're limited by space, and you don't want new wheels I'd look at the StopTech 4-pot front kit for $2495 and similar rear for $2495 Retail. You may need to run a spacer.
Brembo also offers some two piece caliper, less expensive solutions. Including a rear kit for $2095 Retail.
