PICS. Coil Relocation C6
Old Jan 21, 2008 | 02:23 AM
MachineWorks's Avatar
MachineWorks
Default PICS. Coil Relocation C6
What do you guys think, going to machine the mounts off the valve covers and powder coat them wrinkle red. I have about $100 in the project. Also still have to do a little more wire clean up and redo the brake booster hose.
Old Jan 21, 2008 | 02:58 AM
keyplyr's Avatar
keyplyr
Old Jan 21, 2008 | 07:32 AM
BlackZ51Vett's Avatar
BlackZ51Vett
What effect is moving the coils closer to the exhaust headers going to create? Shorten the life of your coils? Thats a lot of heat immediately under/beside your coils..........
Old Jan 21, 2008 | 08:21 AM
ben dover's Avatar
ben dover
From: When all is said and done... there is a hell of a lot more said than done. Riverside,Texas
St. Jude Donor '05 thru '26
The appearance is great but I have the same question.
Old Jan 21, 2008 | 10:09 AM
SpinMonster's Avatar
SpinMonster
Longer wires also suggest a departure from optimum. I will call this a beauty mod but a performance detraction. Its in the same camp as running covers on parts of the engine that will retain heat such as a alternator cover. Those rocker arm covers would sure look good in a nice anodized orange powdercoat.
Old Jan 21, 2008 | 11:56 AM
MachineWorks
Just for looks, so you can clean up the bay a little. It will look better when the valve covers are done. I don't see any real gain in performance from keep the coils coll. Katech won't sell the kit on the C6RS.
This is what I am going for.
Old Jan 21, 2008 | 11:58 AM
Mardis Gras's Avatar
Mardis Gras
I like the idea, but may be biased.
Here's mine with the Katech kit
Old Jan 21, 2008 | 03:33 PM
MachineWorks
With your coil kit you can just make out those badass $500 Katech valve covers. Thats why I went and made this off the cover setup. I am not one of your typical Corvette guys that like to buy everything. I post the finished pics. when I am done.
Old Jan 21, 2008 | 03:41 PM
LSCHLEM's Avatar
LSCHLEM
I want that MAGGIE
Old Jan 21, 2008 | 05:02 PM
EVILNESS's Avatar
EVILNESS
Exept the katech kit and valve covers are a million dollars...
R.
Old Jan 21, 2008 | 05:06 PM
jogar80's Avatar
jogar80
R.
Yup, wish I could find some inexpensive brackets.
Old Jan 21, 2008 | 05:15 PM
EuroRod's Avatar
EuroRod
These brackets and valve covers were made by Nasty Performance.
Old Jan 21, 2008 | 05:24 PM
MachineWorks
]Exept the katech kit and valve covers are a million dollars...
When I am done I'll have maybe $160 in the whole kit. The wires were $95.
Old Jan 21, 2008 | 08:02 PM
EuroRod's Avatar
EuroRod
Which wires are you using?
Old Jan 21, 2008 | 08:10 PM
VET4LES's Avatar
VET4LES
It looks great but I would be concerned about the heat also.
Old Jan 21, 2008 | 09:12 PM
MachineWorks
The wires are MSD 8.5, the clearence between the headers and wires is miss leading from pics.
Old Jan 22, 2008 | 07:11 AM
EuroRod's Avatar
EuroRod
I did not know that MSD made long wires with the correct LS2 coil fittings? I have Taylor wires, and I'm not really pleased with them. Where did you find the MSD's. Thanks.
Old Jan 22, 2008 | 09:40 AM
MachineWorks
Auto Zone, I had to use mod the coil termals a little, but they work. The valve covers are just about ready for powder coating.
To PICS. Coil Relocation C6
