Comments on Pulstarplugs?
Old Jan 22, 2008 | 02:36 PM
gfreeman's Avatar
gfreeman
Default Comments on Pulstarplugs?
Have seen "too good to be true" ads for Pulstarplugs, advertsing up to 10% increases in H.P./torque. Not cheap at $25 ea for an LS/2... any experience out there?
www.pulstarplug.com
Old Jan 22, 2008 | 02:50 PM
5 Liter Eater's Avatar
5 Liter Eater
St. Jude Donor '11
Do a search. A forum tuner did a very complete test of them.
Old Jan 22, 2008 | 02:55 PM
From C6ZO62C8's Avatar
From C6ZO62C8
too good to be true, imo
Old Jan 22, 2008 | 03:10 PM
gfreeman's Avatar
gfreeman
THANKS - knew I should have checked the archives 1st. All I REALLY need is Pulstarplugs, a Turbonator and Mr. Fusion and I'll be making 800RWHP for sure!
Old Jan 22, 2008 | 03:16 PM
FloydSummerOf68's Avatar
FloydSummerOf68
I guess you still didnt do a search then.
The plugs were proven to do good things and performed best on a heavily modified vehicle.
Old Jan 22, 2008 | 03:34 PM
johnodrake's Avatar
johnodrake
Moderator
If it is too good to be true, it is usually - not true!
Old Jan 22, 2008 | 07:31 PM
dkrhardy's Avatar
dkrhardy
$25 a pop? OMG, my 300c has 16 plugs ..... they better not work on that car!
Old Jun 27, 2008 | 10:57 AM
CivicHybrid's Avatar
CivicHybrid
1st Gear
I guess the manufaturer of the 300C thought that more spark was better, since they doubled the spark per cylinder over the stock engine.
Read the results from the Corvette tuner's tests. Their conclusion, after much testing is that they actually do work.
Old Jun 27, 2008 | 11:06 AM
k0bun's Avatar
k0bun
From: NJ..."the way I saw it, everyone takes a beating sometimes."
http://forums.corvetteforum.com/show...hlight=pulstar
Old Jun 27, 2008 | 11:26 AM
Racer86's Avatar
Racer86
[QUOTE=CivicHybrid;1566074054]I guess the manufaturer of the 300C thought that more spark was better, since they doubled the spark per cylinder over the stock engine.
The hemisheriscal combustion chambers in a Hemi have alot of extra surface area. The extra plugs were added to help the flame burn process in the cylinders to get the engine to pass current smog standards. Current cylinder head design has more of a wedge shaped chamber to reduce the surface area which helps the burn process,,, more even temps across the chamber.
Old Jun 27, 2008 | 12:30 PM
Craigster05's Avatar
Craigster05
St. Jude Donor '07-'08-'09-'11-'12
Old Jun 27, 2008 | 02:28 PM
AutoCutter's Avatar
AutoCutter
They are probability easier than indexing spark plugs and they seem to produce about the same amount of additional horsepower. The cost is a bit much when there are easier ways to make HP. I would say that Pulsar's or indexing are best left for when you are trying to find that last little bit of HP needed to win.
Old Jun 27, 2008 | 03:33 PM
AORoads's Avatar
AORoads
St. Jude Donor '15
"In honor of jpee"
no way.
To Comments on Pulstarplugs?
