Tranny and diff fluids
Old Jan 26, 2008 | 08:53 PM
welcome2try's Avatar
welcome2try
From: Objects in your mirror are losing , Long Island, NY
St. Jude Donor '08
Originally Posted by Subdriver
For the daily driver, the 5w40 is probably a good balance between good cold flow and high temp performance and I'll consider that in my CTS-V once it is out of warranty.
I've also dropped you a PM with more info on the AMSOIL Preferred Customer Program
Thank you for the thorough explanation, I think the 5w40 is more my style of driving, I will be ordering some from you soon, thanks for the PM also..BTW my car is out of warranty not worried..
Old Jan 26, 2008 | 08:56 PM
welcome2try
St. Jude Donor '08
My pleasure... and yep, actually still am - Nuclear Submarine Officer with 20 years active duty and counting... which is why I don't post for months at time frequently. Racing my Corvette (and the associate oil sales) are a hobby that I may take full time I retire, though not sure when that will be.
Nuclear Submarine Officer ? You have my order soon, thanks for the services..
Old Jan 26, 2008 | 09:17 PM
Braumeister's Avatar
Braumeister
My recommendation depends a little on that status of your warranty and whether you are willing to use an oil that doen't meet the owner's manual requirements. The LS2 requires an oil meeting GM Standard 47187M. This standard requires a synthetic oil of an xw30 multigrade. Unfortunately, the API's fairly recently introduced SM standard reduces the amount of ZDDP anti-wear additives these oil can use.
I personally believe the High Temp High Shear rating of an oil is a good indicator of how the oil will perform in the engine, particularly for those running the car hard. The High Temperature/High Shear Test measures a lubricant’s viscosity under severe high temperature and shear conditions that are similar to severe service applications in an engine. As such, in my 02 Z06 with an LS6, I run a 10w40, but I can afford to let my oil warm up before I go out on the track. That might not be practicable for a daily driver.
So... these oils are labeled by AMSOIL for use where GM Standard 4718M is called for, in order of decreasing cost/performance:
AMSOIL Signature Series Synthetic 0w30
AMSOIL SAE Synthetic 5w30
AMSOIL XL Synthetic 5w30
All three of these oils have an HTHS rating of 3.2. For comparison, the factory fill Mobil 1 5w30 has an HTHS of 3.09. FYI, I run the predecessor of the above 0w30 in my 06 CTS-V which has a stock LS2 under warranty.
If you are willing to forgo owner's manual requirements, I'd consider one of these:
AMSOIL SAE Synthetic High Performance 10w40 (HTHS 4.3 - this is the oil the thread starter chose for his ZR-1)
AMSOIL Synthetic 5w40 European Motor Oil (HTHS 3.7)
I to am a fan of the HTHS rating on a oil that's why I went with Redline 5W30 which has a HTHS of 3.8, lowered my oil temps 10-15deg also...Pete
Old Feb 5, 2008 | 01:24 AM
tmak26b's Avatar
tmak26b
I love the 5w40 on my Nissan, I am hesistant to switch over to that in the Corvette. I will be going with Amsoil at my next oil change, I am just debating if it should be 5w30 or 5w40.
For tranny, I cant wait to get rid of the royal purple crap. I am debating if I should try Amsoil ATF, ATD or Redline D4
For rear diff, I have 4 bottles of 75w90 Royal Purple here, but I am thinking of getting the 75w90 redline or just get the Amsoil 75w90 severe gear with their 4 oz addidtives.
Old Feb 5, 2008 | 01:53 PM
C66 Racing's Avatar
C66 Racing
Premium Supporting Vendor
If you chose to use AMSOIL in your tranny, I'd lean towards the ATD. Though I've been using the ATF in my 02 Z06 on the track for years and recently put it in my 06 CTS-V, the current version of the ATF has a slightly lower viscosity. Though both are labeled for Dexron III applications by AMSOIL, I think the higher viscosity ATD may be the better choice now. I'll be trying the ATD in my Vette this season as I have gallons of it lying around my garage for my RV which has an Allison transmission.
__________________
C66 Racing #66 NASA ST2, SCCA T2
AMSOIL Dealer (Forum Vendor)
AMSOIL Preferred Customer Program (Members buy at Wholesale - a savings of about 25%)
