Can stoptech calipers be powder coated?
Old Jan 23, 2008 | 01:36 AM
greentank's Avatar
greentank
Default Can stoptech calipers be powder coated?
Thinking of changing the color to match my ride or wheels. Can/has this been done?
Old Jan 23, 2008 | 01:43 AM
bowmanized's Avatar
bowmanized
I'd probably paint them instead. Or have StopTech do it.
What color are you trying to match?
Old Jan 23, 2008 | 11:12 AM
greentank's Avatar
greentank
I was thinking of matching my gunmetal wheels, or monty red body. I found an unused pre-owned BBK kit, but it's red. Red calipers wont work with a monty red body. Black or silver would be better than red also...but if I'm having them coated, I'd do something special.
Old Jan 23, 2008 | 11:45 AM
corvette pilot's Avatar
0corvette pilot
Former Vendor
Yes, they can. I have done several sets, including monterey red, as pictured here:
Old Jan 23, 2008 | 11:52 AM
Busa196's Avatar
Busa196
Corvette Pilot on this forum does them....www.thepowercoater.com
He just did my Z calipers and they turned out awesome. Mike does a great job and turn-around time was minimal. I'd definitely powercoat, not paint- I'ts much more durable.
Here's a pic on mine in Victory Red with the "Corvette" lettering in black instead of white.
BEFORE:
AFTER:
Old Jan 23, 2008 | 11:54 AM
0corvette pilot
Former Vendor
Busa wanted the circles removed on those! I can make them look factory too!
Old Jan 23, 2008 | 11:56 AM
bowmanized's Avatar
bowmanized
Thanks guys, I wasn't sure if you could since the because of the calipers, but then again they are built for resisting heat.
Looks like you have a couple good options there buddy
Old Jan 23, 2008 | 04:25 PM
0corvette pilot
Former Vendor
Originally Posted by fafnir
corvette pilot, out of curiousity how are you doing the logos and text on the calipers if you're powdercoating?
or maybe a different way of asking this would be can you make the "brembo" lettering go away on the new forged monoblocs?
and then if i wanted a new logo on the calipers, how is that added? e.g. is that part of the powdercoating? and would it last?
also, what if the caliper facing was machined? e.g. like those alcons that bowmanized offers? can the lettering on those be removed also?
also, how much would doing a set of brembos or alcons cost?
and do you do nickel plating?
thanks for the time
_
Usually, the stencils are applied and then protected with a coat of clear powder. The only time that is not the case is with any shade of red calipers and light colored letters, as the red will bleed through when the clear is applied. In those cases, its either vinyl stickers or high temp. painted logos with no clear coat.
I can put any logo you want on a caliper.
If the caliper has raised letters, they can be ground off
If the caliper has recessed letters, you are stuck with them.
Old Jan 23, 2008 | 04:27 PM
C6400hp's Avatar
C6400hp
From: DFW This user does not support or recommend the product or service displayed in the ad to the right
I have a set of 4 piston Brembo's on front and back that I need to get redone. How much $$ are we talking about here? What is the typical turnaround time? Will the coating hold up to high temp track duty? Do I need to get new piston seals for you or is that included?
Thanks,
Old Jan 23, 2008 | 04:34 PM
0corvette pilot
Former Vendor
thanks for the time
_
Old Jan 23, 2008 | 05:02 PM
0corvette pilot
Former Vendor
Thanks,
$300 plus shipping, seals not included. Normally I reuse them. If any need replacing, you have to pay for them. I can order them though.
Turnaround is usually 2-3 days for big brakes, unless we are doing custom logos, then it takes a little longer for the stencils
I don't recommend them for track duty though. The color will eventually darken and they won't hold up any better than the factory coating.
Old Jan 23, 2008 | 05:16 PM
C6400hp's Avatar
C6400hp
I guess the best bet is to go with a dark color? Maybe black with a ligher color logo? Something in Competition gey might look cool though?
Old Jan 23, 2008 | 05:23 PM
0corvette pilot
Former Vendor
yea, darker would be better. This is close to comp gray:
Old Jan 23, 2008 | 06:30 PM
C6400hp's Avatar
C6400hp
Yeah, thats a good color,
That with Black Brembo lettering might look pretty good, Of course they will be much more subtle than red but that is not necessarily a bad thing especially if the longevity of the finish will be better. Ohhhh, I know. That grey color with red Brembo logos would look fantastic. Could that be done and how well would the red logs hold up? I am sourcing piston seals now!
Old Jan 23, 2008 | 06:35 PM
C6400hp's Avatar
C6400hp
do you do wheels too?
Old Jan 23, 2008 | 07:17 PM
0corvette pilot
Former Vendor
red logos should hold up fine. I use 1200 degree paint for those.
Wheels, I do, but I don't have the facilities to strip them, and the local places are pretty pricey. Its best to have them stripped locally before sending.
Old Jan 23, 2008 | 09:01 PM
greentank's Avatar
greentank
VERY nice work indeed! I might be able to swap the reds for factory blacks, but a custom color could be very cool too. Here's my car....what do you think would be good for a stoptech caliper color?
If black, I probably have it covered. However, if you can match the wheel powdercoat gunmetal color (Forgeline did the wheels, maybe they can share the color info) and use black or candy red stoptech lettering...that could look good....
To Can stoptech calipers be powder coated?
Old Jan 23, 2008 | 09:05 PM
0corvette pilot
Former Vendor
Is that Mag Red? I can match that, or I can match the other reds also. I could probably send you some gray samples to see if anything is close to the wheels, but I would go with body color myself with black or gunmetal lettering.
Old Jan 23, 2008 | 09:48 PM
C6400hp's Avatar
C6400hp
How much for PC wheels assuming they are prepped properly for you?
Old Jan 23, 2008 | 10:18 PM
0corvette pilot
Former Vendor
50 each.
