Attention 08 owners!
Old Jan 23, 2008 | 07:16 PM
Z51 6spd's Avatar
Z51 6spd
Default Attention 08 owners!
Just wondering if anyone is thinking what I'm thinking. OK, we have a LS3 which is the same motor in the ZR1 minus the forged internals and the titanium valves in the heads.
Has anybody thought about pulling the motor putting forged internals in with the titanum valves, and using the LS9 supercharger or any other boosted system? I mean we are talking some serious, I mean serious power. The 03-04 Cobra mustangs with their forged internal bottom ends do decent with turning up the boost, right now 850rwhp is the record on a stock motor(nothing done to it all, Mike Palugi car). So are LS3s with forged internals would be just as strong or stonger. That Cobra motor tripled its power,but had twin turbo boost. If are motors which would essentially be the same as the LS9 tripled its power. Get my drift, of course the entire drivetrain would have to be beefed up, but the potential of this car is awesome.
What are we wating for? What do you guys think?
Old Jan 23, 2008 | 07:30 PM
Nightclaw's Avatar
Nightclaw
I'd guess that the aftermarket is already well underway building packages to do exactly that.
Old Jan 23, 2008 | 07:34 PM
thegame's Avatar
thegame
I was thinking about that today. If that blower proves to be a great set-up, which I am sure it will, I bet we will see some aftermarket sales within the next few years.
Old Jan 23, 2008 | 08:21 PM
need-for-speed's Avatar
need-for-speed
CI 1-4-5-8-9-10 Vet
St. Jude Donor '03 thru '10, '17
I think plenty of folks are thinking the same as you.
Another consideration might be to do a po-boy version - install the LS9 blower, use only about 60 to 70% as much boost, and install thicker head gaskets to lower CR a bit. Wonder if that would work ?
Old Jan 24, 2008 | 01:18 AM
Z51 6spd's Avatar
Z51 6spd
Yes I'm also considering it.
Old Jan 24, 2008 | 01:54 AM
OneSickZ06's Avatar
OneSickZ06
I was waiting for one of these threads to come up. "We have the same motor as the ZR1's!"
Old Jan 24, 2008 | 02:07 AM
TurboLuigi's Avatar
TurboLuigi
Callaway is doing it with the 2008 LS3 and quoting 580HP for their Supercharger package, 650HP for their C16 package. They have been doing a lot of test, tuning, and validation for their 2008 Supercharger package and just did a press release with the numbers.
-Luigi
Old Jan 24, 2008 | 02:31 AM
jbsblownc5's Avatar
jbsblownc5
2017 C5 of the Year Finalist
St. Jude Donor '08
Has anybody thought about pulling the motor putting forged internals in with the titanum valves, and using the LS9 supercharger or any other boosted system? I mean we are talking some serious, I mean serious power. The 03-04 Cobra mustangs with their forged internal bottom ends do decent with turning up the boost, right now 850rwhp is the record on a stock motor(nothing done to it all, Mike Palugi car). So are LS3s with forged internals would be just as strong or stonger. That Cobra motor tripled its power, it was on 60 pounds of twin turbo boost. If are motors which would essentially be the same as the LS9 tripled its power. Get my drift, of course the entire drivetrain would have to be beefed up, but the potential of this car is awesome.
This is some good stuff!!!
JB
Old Jan 24, 2008 | 07:29 AM
ben dover's Avatar
ben dover
From: When all is said and done... there is a hell of a lot more said than done. Riverside,Texas
St. Jude Donor '05 thru '26
This is going to get very interesting.
Old Jan 24, 2008 | 08:08 AM
thegame's Avatar
thegame
-Luigi
Do you have a link? I thought Callaway is using the maggies?
Old Jan 24, 2008 | 09:31 AM
Michrider's Avatar
Michrider
"OK, we have a LS3 which is the same motor in the ZR1 minus the forged internals and the titanium valves in the heads. "
and minus the block and heads and oil system and intake and exhaust and fuel system and... I'm struggling to think of many common parts between the LS3 and LS9. They share bore spacing, most dimensions, and cam location... but that block and heads for the LS9 is quite revised to pass validation at 620 hp. From what I've read, block strengthened 20% and heads 24%.
I'm guessing these "validated" 650 hp tuner deals use a bit different validation process than the OEM.
Old Jan 24, 2008 | 11:58 AM
andreas g.'s Avatar
andreas g.
I have the LS3 with a 4.100 forged crank, scat rods, Diamond forged pistons and rings. It's L92/LS3 heads are CNC ported flowing 360int/280ex. Even with a compression of 10.9 a blower does sound interesting. In It's present condition it makes 525rwhp/500rwtq. It displaces 427 ci. The only drawback is the cam isn't really a blower cam. It's set up for N/A. I do know Andy Green has his new LS3 A6. He's doing it in stages. Blower, blower and headers,and finally blower , headers, and a cam. I'm sure he's working on as we speak,and he's leaving the internals alone. I'm sure he'll post each stage as they are completed. Something to look forward to.
Old Jan 24, 2008 | 12:39 PM
Kent1999's Avatar
Kent1999
The LS3 block isn't as strong as the LS9 block -- they are _not_ the same "with just different internals".
So the statement that "LS3s with forged internals would be just as strong or stonger" is inaccurate.
Old Jan 24, 2008 | 01:36 PM
Z51 6spd's Avatar
Z51 6spd
Yes this is true that the material which makes up the LS9 is different, block and heads that is. Didn't really feel the need to bring that up seeing that the LS3 block and heads will hold up to 1000+ rwhp without a problem at all. Its one hell of a motor guys, we just need the put forged internals in it with some boost. Guess I got a little excited about it being just as strong as the LS9, but close.
When we put the LS9 charger on that takes care of the intake. As far as exhaust I'm running full exhaust right now anyway. The fuel system is going to have to be upgraded better than the ZR1s anyways do to the power I want to make. What I'm getting at is that it's the same cubic inches/heads and the potential can be the same with some money spent, minus the LS9 having a stronger block/heads. All with a fraction of the cost of the supercar I would love to own one day. I will have to look up this special alloy material I have heard about.
Old Jan 24, 2008 | 01:58 PM
C6Longshot's Avatar
C6Longshot
I haven't seen anyone mention the different pulley layout on the LS9. I would think that this would be a pretty big stumbling block when trying to attach an LS9 blower to an LS3.
Old Jan 24, 2008 | 02:27 PM
robvuk's Avatar
robvuk
Don't forget the internal oiling system and the dry sump. Your LS3 without those things may not live very long. I'm sure GM didn't design and install those things just for fun.
My guess is that you'd be better off waiting to see if you can buy a crate LS9.
Old Jan 24, 2008 | 02:31 PM
Michrider's Avatar
Michrider
A 1000+ horsepower? Maybe for a little while. The only LS block anywhere near that strong is the LSX.
To Attention 08 owners!
Old Jan 24, 2008 | 04:51 PM
OneSickZ06's Avatar
OneSickZ06
With the LS7 crate engine being $12k+. I could just imagine a crate LS9!
Old Jan 24, 2008 | 05:15 PM
Nd4spd2's Avatar
Nd4spd2
St. Jude Donor '08
-Luigi
How about the link for this. I've been waiting on the LS3 blower setup.
Old Jan 24, 2008 | 05:17 PM
Nd4spd2's Avatar
Nd4spd2
St. Jude Donor '08
I'd like to hear more about this. I haven't seen squat on any Ls3 A6 packages anyone is developing.
