TRACTIONMONSTER part of the solution
#401
Someone has been digging in the thread graveyard, I see.
Fear not! One of the mods will come along and lock this before it causes irreparable harm and crashes the forum.
#403
Well the most visited thread of a tech/mod nature (this one) helps people enough that the mods made it a sticky instead of locking it. Let the harmful crashes begin.......
BrownVette (02-24-2016)
#404
Brilliant post...
Pondering for some time on this. Mind made up on widening the stock thanks to thus write-up. Mike at Corvette Shop has the wheels.
Beers tomorrow might Robert! Beer Garden is calling.
Kevin n Sandra
Kevin n Sandra
#405
Well since this thread got bumped I'll say that I'm currently running a 17x9.5" +54 wheel from OEWheels with a 295/45/17 Mickey. Fit perfectly. IMO this is the best and cheapest straight line traction possible without going widebody and spindles to run 15's.
#406
is this the crap tire you used @ ti?
#407
For drag strip duty you want all the gear you can get. Your tall tires would kill my measly 475 RWHP.
By the way my friend is selling a set of your tires if you need some, let me know.
#408
The information in the thread is as salient today as it was when it was posted. And there are a lot of new members who would benefit from the "old guys" like Spin who did a lot of testing and spent their time to write these things up for FREE for others to learn.
#409
Can someone answer me why people post this when threads get brought up again?????? Sheesh
...and when someone posts a new thread, everyone bashes the OP and tell them they should use the search feature...SMH...
#410
Bill probably worth noting that these tall tires are great if you have twin turbos, 1000 rhwp and Nitrous... but for us NA guys with < 500 RWHP, the shorter 275/40/17 or if you have a GrandSport/ZO6 315/35/17 tires are a better solution at about 25.5" high.
#411
#412
https://www.corvetteforum.com/forums...post1588097591
#415
Widen the OEM rear wheel on C6
Spinmonster or anyone has tried this: I want to widen the OEM rear 19"x10" wheel to 19"x11". I use my car for road racing and I want to use the 315 Hoosier in the back. You said the 18"x11" barely touches the control arrm and since I get very light on parts of the track, that could be a problem. A larger diameter wheel might make this not happen but the 19"x10" wheel is already 4mm closer to the inside of the car which works against me. I also run 1.5 degrees negative camber which doesn't help. Has anyone tried this? Thanks.
HC Mechanic (01-10-2018)
#416
