FOB Location
Old Jan 26, 2008 | 10:58 AM
blown34's Avatar
blown34
Default FOB Location
Several times just lately I got in my car and it wouldn't start, just the little crackling noise when I push the start button. I move my FOB from my left jacket pocket to my right jacket pocket and it starts. I thought maybe a weak battery, but I can be over 100 feet away from the car and unlock the doors. Anyone else notice this problem?
Old Jan 26, 2008 | 11:04 AM
drlndrve's Avatar
drlndrve
I've had a similar issue at times, and have felt it was because of the proximity of the fob to my cell phone, causing some type of interference.
Old Jan 26, 2008 | 11:09 AM
Vette_DD's Avatar
Vette_DD
Not unusual. Might be something in your left pocket with the fob that's shielding the signal to/from the fob-detecting antennas in the car. Just be sure you don't have any cell phones plugged in while you're starting the car.
I've had the interference problem about twice in 3 years.
Old Jan 26, 2008 | 11:17 AM
lurtonk's Avatar
lurtonk
The FOB range for lock/unlock is pretty far but to start it is very limited.
I was going to let a friend drive my 08 so I got in the passenger side with the fob in my right pants pocket and it wouldn't start. I took it out and threw it in the cup holder and it started right up.
Old Jan 26, 2008 | 11:36 AM
Kreuzen's Avatar
Kreuzen
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
probably interference - cell phone or something. you could always change the battery....see if its corrects the problem.
Old Jan 26, 2008 | 10:14 PM
wbear's Avatar
wbear
Document ID# 2048652
Subject: Occasional No Fob Detected Message On DIC Or Key In Reminder When Key Fob Outside Of Vehicle - keywords chime chirp horn no program RCDLR RKE transmitter #PIC4642A - (01/14/2008)
Models: 2005-2008 Chevrolet Corvette
This PI was superseded to add revised procedures that will recover the RCDLR when/if the RCDLR "Locks Up". Please discard PIC4642.
The following diagnosis might be helpful if the vehicle exhibits the symptom(s) described in this PI.
Condition/Concern:
Some customers may comment of an occasional "No Fob Detected" message displayed on the DIC when the fob is located somewhere on the driver's seat.
They also may comment that the fob reminder (3 horn honks) is heard when exiting the vehicle with the key fob. This is because the original RCDLR software does not adequately cover the driver's seat and it can also detect the fob when it is slightly outside of the driver's door.
The new software will add a new zone to better cover the driver's seat, and it will also add a 2 second delay after the door closes before checking for the fob on the interior. This could affect all vehicles built prior to October 2007.
Recommendation/Instructions:
Important: Prior to programming per the information below, the Radio and HVAC Fuses MUST be removed and the ignition must be in "Key On Engine Off Mode"
The radio and HVAC fuses can be located in the BCM fuse block on the passengers floor electrical center. One of the fuses is labeled RDO/S'BAND/VICS and the other is labeled HVAC/PWR SND.
Program the RCDLR with revised software using TIS-2-WEB "Pass Through" method. When programming, it is required to select "Replace and Reprogram ECU".
Important: If the programming procedure does not finish successfully and the RCDLR appears to be in a "locked up" state do not turn off the ignition, follow the directions below...
The RCDLR can be reset by removing the RCDLR fuse (#11 in the UBEC) for at least 30 seconds or longer and then reinstalling it.
Once this fuse is reinstalled in the UBEC, there will be a 2 minute window to restart the programming of the RCDLR through TIS2WEB.
Failure to restart the programming of the RCDLR through TIS2WEB within 2 minutes may cause programming to fail and this procedure will need to be repeated.
It is recommended that the Tech 2 remain connected to the vehicle and that the TIS2WEB application is open and ready to program the vehicle prior to reinstalling RCDLR fuse #11 into the UBEC.
Use Labor Operation Number R9723 with a Labor Time of 0.4
Please Note the following two items:: DO NOT REPLACE THE MODULE - JUST REPROGRAM IT. ALSO FOB PROGRAMMING AND TPM LEARN IS NOT REQUIRED.
For Model years 2005-2007, use software version 25927325.
For Model Year 2008, use software version 25927326
Old Jan 29, 2008 | 10:35 PM
blown34's Avatar
blown34
Each subsquent no start was when the fob was with my cell phone; no further problems when the two are in seperate pockets.
Old Jan 29, 2008 | 11:51 PM
Vette_DD's Avatar
Vette_DD
To FOB Location
