Voltage issue. NEED HELP!!!!!!!
Old Feb 2, 2008 | 07:32 PM
Z06 AXer's Avatar
Z06 AXer
Default Engery saving alternator.
I didn't see if mentioned that your battery was discharing, I was told by a service guy at my chevy dealer that the new alternators had voltage sensing circuits to stop charging when the battery reached a certain voltage.
Old Feb 5, 2008 | 07:45 PM
Joe_G's Avatar
Joe_G
St. Jude Donor '08
Default Seat Heater = Service Charging System on my car
I noticed that I only have the "service charging system" when I have my seat heater on (it gets a little chilly in the winter driving to work with my top down at 5 am).
Just a data point. No seat heater, no charging system error. I think I'll just turn the heater on. Matter of fact need to make sure it works anyway!
Old Feb 7, 2008 | 05:34 PM
martypaulk's Avatar
martypaulk
I've also been having the "service charging system" error almost since the day I've owned the car. Dealer has had it 3 separate times now for a total of about 2 1/2 weeks and even had an engineer fly in to check it out. They have never found any problem and have replaced wiring harnesses, alternators, computers. Couple of observations - seems to increase frequency of the error messages as outside temperature increases. Primarily happens only at idle in drive at a stop light although several times I have got it as I'm accellerating away from a stop. If I give it a bit of gas at idle or in park, the problem never shows up. Could this be solved by bumping the idle speed up in the computer a bit?
