Adding a GPS
Old Jan 30, 2008 | 07:20 PM
alicewhails's Avatar
alicewhails
7th Gear
Default Adding a GPS
Hi All, I'm a new member with a question. Does anyone know if i can install a factory GPS/Stereo system in a 2005 coupe that came with the factory 6 disk changer? If so, does anyone have one for sale? Thanks for your time.
Old Jan 30, 2008 | 07:40 PM
traindude's Avatar
traindude
Welcome to the forum!
Just a suggestion --- You stand a better chance of getting an answer to your question if you post it in the C6 section rather than here in the Intros section. I recall seeing a few posts in the C6 General Section asking about adding a GPS afterwards to a C6. I am not sure if those posts are the same as what you are looking to do --- you may want to search that section.
Old Jan 30, 2008 | 07:58 PM
cerino2000's Avatar
cerino2000
Yes you can do it. After you install the head unit you will need to have your dealership turn it on. It will go into theft-lock mode until your dealer matches the vin of your car into the new nav unit.
Old Jan 30, 2008 | 08:06 PM
alicewhails
7th Gear
thanks, i'll post it there.
Old Jan 30, 2008 | 08:07 PM
alicewhails
7th Gear
Thank you for the replys
To Adding a GPS
