dyno results!
Old Jan 30, 2008 | 09:10 PM
darkc6's Avatar
darkc6
Default dyno results!
i have a 2007 c6 mn6 coupe that i recently put on the dyno and i am wondering if these numbers seem accurate for my mods. i have b&b bullet catback exhaust west coast corvette dual cone intake and a predator diablo programmer. the car pot down 355rwhp and 350tq. i have seen stock c6's with these numbers or am i wrong?
Old Jan 30, 2008 | 09:22 PM
Louis @ LG Motorsports's Avatar
0Louis @ LG Motorsports
Former Vendor
Those are a little on the low side, typically I see 350-360 stock, and as high as 363, and as low as 338, so its not too far off, but not a wringer.
Old Jan 30, 2008 | 09:27 PM
darkc6's Avatar
darkc6
i thought they where a little low, im not sure what kind of dyno it was, but my buddy is a diesel mechanic and it was at his diesel shop
Old Jan 30, 2008 | 09:32 PM
corvette pilot's Avatar
0corvette pilot
Former Vendor
I got 340 stock on my 05 on a dyno dynamics, that runs about 10% lower than a dyno jet.
Old Jan 30, 2008 | 09:50 PM
darkc6's Avatar
darkc6
so its nothing to worry about? btw...get to test drive a 2008 zo6 jetstream blue this friday cant wait!!!!
Old Jan 30, 2008 | 10:26 PM
joeszo6's Avatar
joeszo6
I would have a professional tuner work some magic and will most likely pick up some power. Those programmers are one size fits all!
Old Jan 30, 2008 | 10:36 PM
LSCHLEM's Avatar
LSCHLEM
St. Jude Donor '08-'09-'10
340 seems to be the average rwhp for the ls2. The catback will give you very little. The predator is a good tuning tool and you may get about 15 HP more out of your ls2.
Old Jan 31, 2008 | 08:15 AM
Mr. Wonderful's Avatar
Mr. Wonderful
From: Slower than a speeding bullet................ Fort Lauderdale, FL
I had a Vortex CAI and 160 stat installed.
Then a dyno tune on a Mustang dyno.
Results: 385 rwhp
Those were the only modifications.
Old Jan 31, 2008 | 01:39 PM
Ted P's Avatar
Ted P
Results: 385 rwhp
that is really good for an 07 with just the two mods
Old Jan 31, 2008 | 05:45 PM
blackvette101's Avatar
blackvette101
Results: 385 rwhp
HOLY S$#T you got those numbers on a mustang, thats would easily be over 400 wheel on a dyno jet
Old Jan 31, 2008 | 08:38 PM
LSCHLEM's Avatar
LSCHLEM
Default 385 RWHP w CAI
Results: 385 rwhp
I wouldn't mind seeing the dyno sheet on that one. The area under the curve should be most interesting. Please post it if you can.
Old Jan 31, 2008 | 10:03 PM
bigdogk9's Avatar
bigdogk9
Is the 350-360 before a tune? or after?
Old Jan 31, 2008 | 10:11 PM
k0bun's Avatar
k0bun
From: NJ..."the way I saw it, everyone takes a beating sometimes."
No offense but I have always found LG's dyno results to be slightly higher than most.
You're fine don't worry about it. When I had my car dyno'd with VR, Borla, tune, and 4.10s I was 345/340. Even adding back the 10-15 lost from the gears would only put me at 355-60/350-55. Similar to yours with comparable mods. You should have gotten a before dyno. Comparing numbers from one car to another, or one dyno to another, etc. is pointless and just makes for headaches and aggrevation. Use the dyno as a tuning tool. If at all possible run on the same dyno. Use it to compare numbers from each mod you install so you can see how much you gained. That is the best way to read the numbers.
Old Jan 31, 2008 | 10:25 PM
0corvette pilot
Former Vendor
I have always heard that Mustang dynos were about 10% higher than a dynojet.
Like K0bun said, its a tuning tool not a real measurement anyways.
Old Jan 31, 2008 | 10:57 PM
08 REDVETTE's Avatar
08 REDVETTE
call the COW
Old Feb 1, 2008 | 01:07 AM
Vetteoholic's Avatar
Vetteoholic
A buddy of mine has an 06' GTO 6M and he put down 351 rwhp and 355 rwtq stock on a dynojet. He said that he has one of the stronger ones. If you were stock with your current #'s that would be great. With your mods you should probably be a bit higher. I would have a pro look at it. Those are still great numbers either way but they probably should be slightly higher. Best of luck and happy modding
Old Feb 1, 2008 | 01:21 AM
KM1959's Avatar
KM1959
I wouldn't do it unless you're ready to part with $75K...
To dyno results!
Old Feb 1, 2008 | 10:07 AM
LS2-Zomb!e's Avatar
LS2-Zomb!e
364rwhp bone stock here
Old Feb 1, 2008 | 12:12 PM
vettecop1125's Avatar
vettecop1125
CI 7-8 Veteran
St. Jude Donor '03-'04-'05
My 07 6 speed was 353/357 bone stock with 450 miles on a dynojet.
Old Feb 1, 2008 | 12:17 PM
pwoolford's Avatar
pwoolford
St. Jude Donor '08
My 2005 MN6 with Magnaflow catback, K&N air filter, and ported intake put down 367 on a Dynojet a couple months ago. I'm wondering what i will pick up with headers and high flow cats? They are probably next.
