Door Opening and Window Indexing
Tonight, after I did get in and start driving I noticed the window did not index back up. I couldn't force it up with the window control. I stopped and opened the door and shut it again. The window went wild! Indexing up, down, up, down, etc. until I opened the door again and closed it. It did not index up until I went a couple of miles down the road. What gives with the indexing?
Hey there Fire69Ice,
Try this.
From inside the car.
1) Turn on accessory mode (yellow light should be on);
2) Lower driver's side window all the way down;
3) Raise window and hold up position for 3 seconds
4) Hold for another 3 seconds;
5) Repeat for the passanger's side window;
6) Turn off accessory switch;
7) Put emergency brake on and car in park if an A4 or reverse if an MN6 transmission;
8) Exit car and watch if driver's side window indexes when you shut the door;
9) Go to passanger side open door anbd shut again....watch if window indexes properly.
I beleive the above reset procedure is covered in the owner's manual..I had to do it recently on my 08 Z06 when I was on a long road trio so I'm familiar with this $hit.
Bernie
after i removed it.
now i have to go to dealer. UHHHHHH
Try this.
Bernie
Hours before a planned vacation, my driver's door quit indexing to full up position. Your procedure fixed it in 90 seconds. My wife will think I am a genius.
Must have happened when I left the radar detector on for several days, without driving the car. Battery went all the way down - which probably confused the indexing function.
