Update on "Dead Again"!!
Your operating system has been superceded with a new on that address's a battery drain issue.
I would have the PCM reflashed at the dealer. If you have a tune in the car it will be wiped out so make sure you either have a backup or your tuner does.
Howard
Was your tune done locally??
I sent you a PM about the DTC stuff. Some of the current update is to address several "false" DTC's that can occur causing the technician to chase his ***.
Howard
This is why ever car I tune I check for OS updates prior to tuning!
Howard
Dead Battery, No Crank/No Start (Reprogram Remote Control Door Lock Receiver (RCDLR) #07-06-03-001B - (03/21/2007)
Models: 2005-2007 Cadillac XLR (Including XLV-V)
2005-2007 Chevrolet Corvette (Including Z06)
Built Prior to the Following VIN Breakpoints:
This bulletin is being revised to update the correction information. Please discard Corporate Bulletin Number 07-06-03-001A (Section 06 -- Engine/Propulsion System).
Model
VIN Breakpoint
XLR
75600571
Corvette
75112132
Condition
Some customers may comment on a dead battery after the vehicle has been parked for a extended period of time. Typically, the battery will last approximately two weeks, depending on the initial state of battery charge.
Cause
A software anomaly within the remote control door lock receiver (RCDLR) causes an additional 30 mA draw on the battery when passive locking is enabled and the vehicle is parked.
Correction
Do This
Don't Do This
Reprogram the RCDLR.
DO NOT replace the RCDLR.
Important: Use the Pass-Thru method when programming and select "Replace and Reprogram ECU."
A new calibration has been released to correct this condition. Reprogram the RCDLR using SPS. This new service calibration is available on TIS2WEB.
Important: On Corvette models, prior to reprogramming, remove the Radio/S-Band/VICS 15-amp fuse and the HVAC/PWR SND 10-amp fuse from the I/P electrical center (passenger floor). Also, the ignition must be in the "Key On Engine Off" mode.
If the programming does not finish successfully and the RCDLR appears to be in a "locked-up" state, DO NOT turn off the ignition, it can be reset by removing the RCDLR fuse (#11 in the UBEC) for at least 30 seconds and reinstalling it. If the ignition was turned to OFF after the "locked up" condition occurred, its possible to continue programming by adding the VIN manually in TIS.
Tip
Transmitter programming and tire pressure learn procedures are NOT necessary after this reprogram.
Please refer to SI for additional information on other potential causes of battery drain.
Warranty Information
For vehicles repaired under warranty, use:
Labor Operation
Description
Labor Time
R9723*
Remote Control Door Lock Receiver -- Reprogramming with SPS
0.4 hr
* This is a unique labor operation number for bulletin use only. This number will not be published in the Labor Time Guide.
Specifically nothing will be found on examination, but the DBS will be cured with the reflash.
One thing you can try to see if you have DBS:
This works for me especially if I park on a steep uphill.
Shut down properly in reverse, and then move the shifter to neutral.
Sometimes mine says to shut down in reverse, proving that the process didn't register.
Now why the radio went south, I haven't a clue.
Anyone know of any in the Northern Burbs of Chicago?
Howard definitely knows his stuff, we've had a few conversations in the past. Basically the new OS that will be programmed into the computer will be the same tune file with a different patch that affects the DBS issue, so you should still be right where you were before the flash. I know it still might be a hike, but the guys at Bill Kay (Bolingbrook) do a lot of aftermarket installations on vettes for their customers (headers and such). Talk to Rich or George.
