'05 vs '06 Corvette Z51
Others posted on my other thread that the '05 had column lock problems? delaminating problems? Also, that it had to be shutdown in reverse?
Hear of those above problems?
Thanks.
Happy hunting!
It's nice for highway cruising.
Recalls/ Service Bulletins
Recall lists: http://www.corvetteactioncenter.com/....php?catId=111
Roof delamination links:http://forums.corvetteforum.com/show...p?p=1555485017
Service Charging system warning: http://forums.corvetteforum.com/show....php?t=1414082
Rear end chatter when cold: http://forums.corvetteforum.com/show....php?t=1249546
Power steering hose: http://forums.corvetteforum.com/show...73&forum_id=74
Roof delamination: http://forums.corvetteforum.com/show...16&forum_id=74
Dash "hoot" "groan" from under dash: http://forums.corvetteforum.com/show....php?t=1040150
Blocked first gear shift http://forums.corvetteforum.com/show...1&forum_id=101
A/C blowing hot preliminatry information bulletin: http://forums.corvetteforum.com/show...78&forum_id=74
Brake Squeal bulletin and fix: http://forums.corvetteforum.com/show...14&forum_id=74
http://forums.corvetteforum.com/show...05&forum_id=74
Crank Pulley issue VIN numbers: http://forums.corvetteforum.com/show...47&forum_id=74
Fuel Sending Unit: http://forums.corvetteforum.com/show....php?t=1060074
Crank pulley bolt TSB & info: http://forums.corvetteforum.com/show....php?t=1038771
Crank pulley complaints: http://forums.corvetteforum.com/show...st15501468 69
6-speed snap ring recall: http://forums.corvetteforum.com/showthread.php?t=930805
VINs in snap ring range: http://forums.corvetteforum.com/showthread.php?t=932613
Brake line safety recall: http://forums.corvetteforum.com/show...ghlight=recall
http://forums.corvetteforum.com/showthread.php?t=949354
Known issues (not experienced by all):
Airbag light illuminated intermittently:http://forums.corvetteforum.com/show....php?t=1529443
Delamination top update for C6 and Z06:http://forums.corvetteforum.com/show....php?t=1426785
http://forums.corvetteforum.com/show....php?t=1432192
Convertible Wind noise top up: http://forums.corvetteforum.com/show....php?t=1390008
Dead Battery Issue: http://forums.corvetteforum.com/show...st15536597 08
Dead batteries: http://forums.corvetteforum.com/show...3&forum_id=101
CV boot leaks: http://forums.corvetteforum.com/show...90&forum_id=74
Rear Axle seal failures: http://forums.corvetteforum.com/show...46&forum_id=74
Brake line failures: http://forums.corvetteforum.com/show....php?t=1113860 http://forums.corvetteforum.com/showthread.php?t=927500
Squeaks and rattles: http://forums.corvetteforum.com/show....php?t=1045781
Trunk button sticking & repair link: http://forums.corvetteforum.com/show...00&forum_id=74
A/C blows hot air: http://forums.corvetteforum.com/show....php?t=1117263
A/C fix: http://forums.corvetteforum.com/show...61&forum_id=74
Fuel Sending Unit / Fuel warning on DIC: http://forums.corvetteforum.com/show....php?t=1060074
Fuel pump connector failure: http://forums.corvetteforum.com/show....php?t=1116191
Convertible power top: http://forums.corvetteforum.com/show....php?t=1055828
Cracking Z51 rotors: http://forums.corvetteforum.com/show....php?t=1046511
Overfilling fuel tank gives Engine Light: http://forums.corvetteforum.com/show....php?t=1042223
Cold Weather window indexing: http://forums.corvetteforum.com/showthread.php?t=973590
CD Changer bug: http://forums.corvetteforum.com/showthread.php?t=900908
Dead batteries - bad relay:
Dead batteries and manual tranny: http://forums.corvetteforum.com/showthread.php?t=928291
Intermittant electrical problemshttp://forums.corvetteforum.com/showthread.php?t=924597
Front License bracket: http://forums.corvetteforum.com/showthread.php?t=925949
Brake squeal after washing: http://forums.corvetteforum.com/showthread.php?t=922848
Aftermarket bracket: http://forums.corvetteforum.com/showthread.php?t=915341
Incorrect Air Filter # in manual: http://forums.corvetteforum.com/showthread.php?t=925171
Loose crank pulley: http://forums.corvetteforum.com/showthread.php?t=919069
http://forums.corvetteforum.com/showthread.php?t=940446
Water in rear view mirrors: http://forums.corvetteforum.com/showthread.php?t=924155
F55 suspension inoperable: http://forums.corvetteforum.com/showthread.php?t=903703
Manual tranny chattering: http://forums.corvetteforum.com/showthread.php?t=921011
NAV locking up: http://forums.corvetteforum.com/showthread.php?t=920242
Intermittent rear hatch open: http://forums.corvetteforum.com/showthread.php?t=917850
Brake squealing: http://forums.corvetteforum.com/showthread.php?t=916234
Missing HOMELINK: http://forums.corvetteforum.com/showthread.php?t=916057
Difficulty programming HOMELINK: http://forums.corvetteforum.com/showthread.php?t=956591
Window indexing prob: http://forums.corvetteforum.com/showthread.php?t=931055
Tire pressure discrepancy: http://forums.corvetteforum.com/showthread.php?t=915838
Orange peel: http://forums.corvetteforum.com/showthread.php?t=915802
http://forums.corvetteforum.com/showthread.php?t=807721
Loose plug wire: http://forums.corvetteforum.com/showthread.php?t=914975
Poor rear viz: http://forums.corvetteforum.com/showthread.php?t=913257
Wavy rear glass: http://forums.corvetteforum.com/showthread.php?t=911082
Squeaky roof: http://forums.corvetteforum.com/showthread.php?t=906606
Carpet fit’n’finish: http://forums.corvetteforum.com/showthread.php?t=913121
Locking seat belt: http://forums.corvetteforum.com/showthread.php?t=912562
Scraping: http://forums.corvetteforum.com/showthread.php?t=908448
Military time in radio: http://forums.corvetteforum.com/showthread.php?t=907312
Air Bag stickers: http://forums.corvetteforum.com/showthread.php?t=907815
Ticking soundhttp://forums.corvetteforum.com/showthread.php?t=923699
MISC problem list: http://forums.corvetteforum.com/showthread.php?t=913864
Door gaps and adjustments: http://forums.corvetteforum.com/show...st15487108 68
Z51 directional rotors mounted on wrong side: http://forums.corvetteforum.com/showthread.php?t=939034
Hood Emblem Peeling: http://forums.corvetteforum.com/showthread.php?t=940588
Clicking noises while driving, troubleshooting tips: http://forums.corvetteforum.com/showthread.php?t=940930
Broken door buttonhttp://forums.corvetteforum.com/showthread.php?t=940738
Passenger door rattle: http://forums.corvetteforum.com/show...st15487757 11
I did have one mechanical problem, but I suspect I was the cause of that one. I got in a hurry while frustrated in a parking lot, and ended up jamming the shifter button somehow where I couldn't shift it out of N/D (I have the A6). I drove it home okay but had to leave it in accessory mode overnight, which naturally drained the battery.
Oh, and I have a phantom leak in the left front tire. It loses pressure at an average of 1-2 lbs a week. Very wierd. I had it to Goodyear twice and they can't find any leaks.
