1st-4th shift skip touble code p0803?
4th shift skip. Why am I getting this light. The 1st 4th shift skip bypass is still working.
Another CAGS eliminator failure, this time with a fix
I put a skip shift eliminator in my new C6 in October. After two months' service, I got a check engine light a couple days ago.
After some of the posts I'd seen in the last two years on the list, I suspected the CAGS eliminator. I decided to try OnStar's remote diagnostics service, since you can't read codes in the DIC like on a C5 (@#&$*! - thanks for that bit of dealer market protection, GM!). Within about 20 seconds the operator reported the CEL was due to a powertrain code, and the code indicated a problem in the CAGS circuit.
So, I removed the CAGS eliminator and put the ohmmeter to it -- infinite resistance (open circuit) I plugged the original CAGS connectors back together, and the CEL cleared a few starts later.
I wanted to take the eliminator apart, but waited until I contacted the vendor to see whether they wanted it back. A to Mid-America Motorworks -- after a couple basic questions to establish that it really was a CAGS eliminator failure, I was told a new one would be one its way Monday, and I didn't have to return the first eliminator.
Here's what I found upon removing the RTV plug on the end of the eliminator: a poor quality solder joint on one end of the resistor, which simply came apart:
A bit of time, solder and RTV, and this unit is back together.
Just an "info" post that hopefully will be helpful to someone in the future.
Mark
