LS3 Oil Temps?
Old Feb 5, 2008 | 09:44 PM
jojog's Avatar
jojog
Default LS3 Oil Temps?
What kind of oil temps are you A6, LS3 owners seeing? Did a search but couldn't find too much feedback. It does seem the LS3 runs hotter oil temps than LS2 engines. Thanks!
Old Feb 5, 2008 | 11:37 PM
LS1LT1's Avatar
LS1LT1
I'd heard of a few cases where the LS3s ran slightly hotter coolant temps than the LS2s but not sure about the oil temps, could be related though.
Old Feb 6, 2008 | 06:07 AM
jojog's Avatar
jojog
ttt
Old Feb 6, 2008 | 08:34 AM
Michrider's Avatar
Michrider
Leave the DIC on odo and drive the car.
Every new engine that comes out, the chicken littles freak out that the oil actually has temperature in it. Normal. More hp = more heat. Newer engine = more heat. No wonder older, less powerfull engines, run at a slightly lower temperature.
Start car, turn on radio, drive.
Old Feb 6, 2008 | 12:26 PM
andreas g.'s Avatar
andreas g.
I've got A forged 427, built from an LS3/ls9 motor making over 525rwhp and my oil temps are the same as my LS2 motor. No difference. Normal driving my temps are 208-214 degrees. Not sure why you think they would be higher. If anything I would think mine would be somewhat higher, but there not.
Old Feb 10, 2008 | 09:52 PM
Sayfoo's Avatar
Sayfoo
Today in Santa Anna, Ca. 86 deg air temp. Cruising on freeway at 70+ mph in 6th. Water temp @ 203 and oil at 228. '08 manual with 5500 miles.
Old Feb 11, 2008 | 02:13 AM
jbsblownc5's Avatar
jbsblownc5
2017 C5 of the Year Finalist
St. Jude Donor '08
I have an 08 Z51 stick. When on the roadcourse or hitting the canyons hard, my oil temps get pretty high! I've seen 260+, but the coolants are only 200 to 210...
I may go with a bigger oil cooler for the summer.
JB
Old Feb 11, 2008 | 02:08 PM
1.8t's Avatar
1.8t
After my 160t-stat my coolant temps run ~180deg and my oil temps run ~187deg all the time . Would honestly like to get the oil temps a bit hotter, but I change the oil frequently to prevent sludging. Ambient temp during evaluation thus far has been anywhere from the 20's to the high 50's. I expect the oil temp to run 5~10deg hotter during the summer with the coolant temps staying pretty much the same.
Old Feb 11, 2008 | 03:00 PM
Michrider's Avatar
Michrider
Your comparing apples to oranges, a modded motor to a stocker. Probably different tuning, stat, clearances ....
Comparing an LS2 to an LS3, it's a good comparison to show more power produces more heat. Very similar engines, cooling systems, tuning paramters, clearances... main diff being one generates about 30 more hp. Power is heat, the oil gets a hair hotter.
But it's no biggie, synthetic can handle temps way hotter than anything mentioned here. Get up into the upper 280's and you'll see a warning, but even then synthetic oil is just starting to sweat. 290sh/300sh, then I'd really say uncle and start cooling things down with either less aggressive laps or added cooling system capacity oil and water.
260 = heck you did that oil a favor, helps cook out the moisture.
Old Feb 12, 2008 | 12:53 PM
andreas g.'s Avatar
andreas g.
Not really, My LS3 stroker uses the same clearences as any other LS type motor. As A matter of fact, there the same clearences that have been used in small bock motors for the last 40 years. These aren't swiss watches. .003 main bearings, .0025 on the rods. Same as used on my big blocks on the 1960's. The only clearence that is different is the piston to cylinder wall set at .0055 forged piston, vs .002 cast piston. You guys know as well as I do that a brand new motor is what we call tight which means it takes a little time for the bearning wear patterns to establish themselves with the journals giving the proper clearence. Or what we call broken in. Oil temps reflect driving conditions, outside temp, and what type of driving your doing, etc. no matter if it's an LS1,LS2,LS3, LS7 or a custom stroker.
To LS3 Oil Temps?
