Tire Pressure Sensor
Old Feb 5, 2008 | 11:04 PM
Mez's Avatar
Mez
From: Austin, Singapore, Kuala Lumpur, Houston, Dallas, Hong Kong, Elgin, etc.. Texas
Default Tire Pressure Sensor
One of my tire pressure sensor is showing "xx" on the DTC. I suppose it needs to be replaced.
According to the Service Manual, first you have to remove the tire from the wheel, replace the sensor, then using a special device, program the sensor to the receiver.
Has anyone done this? Should I have the dealer do this?
Old Feb 5, 2008 | 11:25 PM
BEZ06's Avatar
BEZ06
I see you have some aftermarket wheels. Did you put them on recently?
Are the sensors mounted inside the wheels with bands or brackets?
If they are, you have a fairly common problem that occurs when the sensors are deeper inside the wheel/tire than the stock mounting method. This is usually especially a problem with the rear wheels.
Is your problem with a rear wheel?
I would suspect that you don't have a bad sensor, you have a problem with how it's mounted.
Take a look at this post:
http://forums.corvetteforum.com/show...4&postcount=32
Bob
