A quick Q re "Priority Start"...
Old Feb 7, 2008 | 02:14 AM
exukboy's Avatar
exukboy
Default A quick Q re "Priority Start"...
I'm still having dead batt probs with my 05 C6. When the "Priority Start" actually kicks in due to detecting a voltage drop, does one still have to go thru the motions of opening the hatch/trunk lid with the regular key then pulling the cable to open the drivers door to put ones foot on the brake pedal to re establish a connection or will simply touching the outside door solenoid sensor pad re activate/connect the battery?
Thanks in advance.
Old Feb 7, 2008 | 05:41 AM
prs62's Avatar
prs62
St. Jude Donor '05-'07
If PS disconnects the battery you have to get in by using the key to open the hatch and pull the door cable. Also, pushing the brake pedal will not re-connect the battery; you have to push in the cigarette lighter.
Old Feb 7, 2008 | 07:51 AM
VET4LES's Avatar
VET4LES
If you have a bad battery the PS will not help. In addition have you had the flash? Some auto's also have DBS problems and can get the flash.
Old Feb 8, 2008 | 12:05 AM
exukboy's Avatar
exukboy
Thanks for the feedback. I haven't had the flash done but I did hear it wasn't 100% reliable. I normally just disconnect the batt when I'm not using the car but I was hoping that with the PS I wouldn't have to mess around with the key etc, I thought just pressing the door button/pad would work to reconnect the batt.
Old Feb 8, 2008 | 01:04 AM
siffert's Avatar
siffert
I got rid of my oem battery and my PS. The PS actually is also a drain on your battery. I got an Optima Yellow Top and all my battery related problems went away.
To A quick Q re "Priority Start"...
