predator u7191 crom file needed
Old Feb 7, 2008 | 07:41 AM
ABvette's Avatar
ABvette
8th Gear
Default predator u7191 crom file needed
I own a 2005 c6 vette and I bought a predator programmer in 2006 from westcoastcorvettes.
My predator serial number is 128581
last week I decided to download a new software for the first time and from diablosport web page from downloads section.
I downloaded the programmes and the u7191_gm_E40-8r09 (crom) 965k file.
I ınstalled the crom file to the predator and up to that point there is no problem
when I tried to install the crom file to the car it says data 12595692 not found in the veichle.Diablosport comp told me that I have to update my car's PCM. But I live in ISTANBUL TURKEY and there is no offical GM dealer here.I can not get my PCM updated
now my predator is blocked i can not install the performance tune and I have to drive the car with the original factory software and my car has seriously cooling problems because the fans work late.
Now I need a crom file which was initially installed in my predator. (or the latest performance tune that is suitable for my car without any need to update PCM).I checked the web page but I can only find the E40-8r09 which did not work with my car.Is there somebody who can send me a file link to solve my problem.
Old Feb 7, 2008 | 09:16 AM
BEZ06's Avatar
BEZ06
PM me your email address and I'll send you some old files as email attachments. I've got the same problem as you - my PCM can only use the old files, so I've got one that will work with your car.
Bob
Old Feb 7, 2008 | 04:31 PM
ABvette's Avatar
ABvette
8th Gear
thank you.
the file 7r93 worked in my car.
"For those who are going to update their predator you must have your PCM also updated at a GM dealer."
To predator u7191 crom file needed
