Koni FSD install question...
Old Feb 9, 2008 | 03:31 AM
Carnac's Avatar
Carnac
Default Koni FSD install question...
I installed a set of Koni FSD shocks this weekend. Love the ride and handling so far (haven't had a chance to push the car much).
My question - the stock (05 C6 Z-51) shocks had rubber covers/boots over the exposed shock rod. The Koni's did not come with boots, and the stock ones don't fit (unless I drilled out the washer). Should I try to get the stock boots to fit or are the exposed Koni rods fine? I guess the stock boots don't really provide much protection, just wondering what others have done.
One more thing, my Koni's are gold and the right part number for a C6, but don't have the FSD label like I saw on a set of used ones for sale. They just say Koni and have the Koni boomerang looking logo after the name.
Thanks - install went well with all the good ideas on the forum (ratchet strap worked great for removal). Jim
Old Feb 9, 2008 | 09:12 AM
davekp78's Avatar
davekp78
C1 of Year Finalist (stock) 2019
2016 C1 of the Year Finalist
2015 C2 of the Year Finalist
I installed the OEM shock covers. A SLIGHT enlarging of the hole with a rat tail file is all it took.
Old Feb 9, 2008 | 10:15 AM
ByByBMW's Avatar
ByByBMW
St. Jude Donor '06-'08-'10-'11-'12-'13 '14-'15-'16-'17-'18-'19
Originally Posted by dave pawlowski
I installed the OEM shock covers. A SLIGHT enlarging of the hole with a ----------.
, doesn't take much.
Old Feb 9, 2008 | 10:16 AM
07MontRedcp's Avatar
07MontRedcp
There should be install instructions in the box that tell you which parts to reuse and how to modify the stock dust covers.
BJK
Old Feb 9, 2008 | 04:54 PM
csun213's Avatar
csun213
So the stock cover should be used with the Koni FSD? Just receive them and have not open up the box yet.
Old Feb 9, 2008 | 04:57 PM
07MontRedcp
Yep. Should be covered in the written instructions that are in the box.
BJK
Old Feb 10, 2008 | 03:46 AM
Carnac's Avatar
Carnac
Default Thanks for the replies...
I'll have to check the box again, but I didn't see anything in the instructions about reusing the boot, just generic stuff. Do I use the OEM yellow/white bump-stop too? Thanks again - guess I'll be pulling the shocks again. At least the Konis are easier to compress. Jim
Old Feb 10, 2008 | 02:23 PM
07MontRedcp
Here is the original thread that started it all:
http://forums.corvetteforum.com/show....php?t=1578755
I will edit this replay as I find more stuff.
BJK
To Koni FSD install question...
