Plz Help
Old Feb 9, 2008 | 11:47 PM
rollin18's Avatar
rollin18
Default Plz Help
My drivers door wont open anymore!!
except only by the manual release levers.
i cant get into the dealer until over a week from now.
i have tried.. 2nd remote, using inside unlock button. using every electronic way all I hear is relays clicking. window still works,
un hooked battery for 30 min still have same problem
the pass door works fine.
any ideas untill then??
thanks!!
Old Feb 10, 2008 | 11:14 AM
timd38's Avatar
timd38
Did you check the fuse?
Old Feb 10, 2008 | 12:02 PM
LSCHLEM's Avatar
LSCHLEM
St. Jude Donor '08-'09-'10
Default Driver Door Wont Open
The door LATCH / UNLATCH is controlled by the " BODY CONTROL MPODULE. The 15 amp fuse controls both the passenger and driver
control locks. If you hear clicking but the door wont latch or unlatch
then the problem is most likely the " Driver unlatch pcb relay" or a loose connector around it.
Old Feb 10, 2008 | 02:09 PM
rollin18's Avatar
rollin18
thanks for the suggestions!!
however, i would think that if the fuse was blown niether door would work.
in my case its JUST the driver door from the out side
Old Feb 10, 2008 | 02:21 PM
LSCHLEM's Avatar
LSCHLEM
Correct about the fuse. Do you hear clicking if you try to use the open close switch on the drivers door ?
Old Feb 10, 2008 | 03:14 PM
rollin18's Avatar
rollin18
yes i hear a quiet clicking from inside the car center dash area, and the red led comes ON. (the window is down so i can open door manually)
Old Feb 10, 2008 | 03:34 PM
LSCHLEM's Avatar
LSCHLEM
The clicking under the dash i believe is the body control module. The click is the relay but when the relay is commanded on the current to the door latch solenoid is not passing thru the contacts of the relay.
If you had a scan tool you could read the error message. Then let me know.
Old Feb 10, 2008 | 03:35 PM
chucky7's Avatar
chucky7
Is your battery in the car almost dead? This happened to my car and the doors acted the same way.
Charlie
Old Feb 10, 2008 | 03:48 PM
rollin18's Avatar
rollin18
Charlie
Charlie,
thanks for the suggestion, my battery is very good! all this happened after installing window valet, have since removed it.
To Plz Help
