top creeking noises
Old Feb 10, 2008 | 11:51 AM
michaelsfxr's Avatar
michaelsfxr
Default top creeking noises
Is it common for top creeking noises.new 2008 z51 How to solve this problem. Thanks in advance
Old Feb 10, 2008 | 12:27 PM
TYake's Avatar
TYake
8th Gear
Default creaking noises in the top
There was (is) a recall for the tops on the 2005 C6 coupes. The top skin evidently can come loose from the frame, and there had been a few reports of the skin departing the car. My 2006 coupe had the squeaks when it was new. The recall didn't include my VIN, but then GM changed their mind. The dealer injected some adhesive and it's all better now. So, gripe to the dealer.
Old Feb 10, 2008 | 04:31 PM
COALMINER,KY's Avatar
COALMINER,KY
Good luck getting it fixed, had that problem on my 2006 model. the dealer fixed it, and it took them 6 weeks. So i would go now if you want it fixed by spring. The problem is getting the parts, with so many to fix its hard for the dealerships to get the parts.
Old Feb 10, 2008 | 11:39 PM
8mywal8's Avatar
8mywal8
Super Glue it!!!!!!!!!!!!!!
Old Feb 11, 2008 | 08:28 AM
FloydSummerOf68's Avatar
FloydSummerOf68
I'm just going to weld my roof to the car, lol.
Old Feb 11, 2008 | 10:20 AM
JLargo's Avatar
JLargo
I put some bearing grease on the rollers, the front pins and the front sockets. I did this 2 weeks ago and haven't heard the creaking since.
Old Feb 12, 2008 | 08:23 AM
twfreightman's Avatar
twfreightman
I fixed mine and it has not made a sound in 6 months. I loosened the torx head bolts that hold the latch handles to the roof and I keep them only finger tight. I keep a little torx head socket in my console and check them pretty often to make sure they are not too loose. I just screw them in as tight as I can with my torx head socket and my fingers. Any tighter than that and squeaking and creeking begins. Works for me. Good luck.
Old Feb 13, 2008 | 10:44 AM
vettechictwins's Avatar
vettechictwins
St. Jude Donor '08
Default roof
When ours creeks, we simply unlatch it take it off and put it back on. Stops for about 6 weeks
Old Feb 13, 2008 | 12:05 PM
florida Al's Avatar
florida Al
Cruising
The roller is slipping on the pin I put 50lb fishing around pin to keep roller from moving acts like a washer and noise was gone
To top creeking noises
