2008 - "H" or "X" pipe
Old Feb 11, 2008 | 03:13 PM
C746490's Avatar
C746490
Default 2008 - "H" or "X" pipe
Does the 2008 non-Z06 have the H or X pipe and what advantages/disadvantages are there?
Old Feb 11, 2008 | 03:25 PM
KGB6's Avatar
KGB6
X pipe info:
http://www.carcraft.com/techarticles...ion/index.html
This seem pretty sound. It's from another forum:
H Pipe:
An H pipe helps equalize the exhaust pressures between the two banks of tubing as the hot gases and sound waves travel down the tubing. This, in effect, relieves the exhaust pressures as they travel through the H tubing, generally creating an increase in torque. This will also give an added sound reduction when the sound waves combine inside the H tubing.
X Pipe:
An X pipe will actually help to scavenge exhaust pulses from one bank as the opposite exhaust pulse passes through the X, thus creating a vacuum effect at the valve, resulting in a cleaner burn in the cylinder. This generally equals added torque and, like the H pipe, a reduction in sound as the sound waves combine in the X pipe.
Y Pipe:
The Y pipe, which works well on several applications, utilizes a dual exhaust off the manifolds/ headers and runs back a specified distance, then the two pipes enter the Y pipe and become one larger pipe. This Y helps each bank to scavenge the other as the pulses travel down through the Y and are joined together into the single common tubing. This creates a vacuum in the exhaust valve, resulting in a cleaner burn in the cylinder. A sound reduction is also achieved as the sound waves combine in the Y pipe.
For your application, since right now it seems to be rather mild, a GOOD Y pipe with a single pipe going to the back and then a mufller that splits them should work great. (I did that in my 91) Remember that your exhaust goes right by the footwell on the passenger side. With true dual it might get rather hot since your stuffing 2 pipes in a space where a single pipe used to be.
Old Feb 11, 2008 | 03:52 PM
FloydSummerOf68's Avatar
FloydSummerOf68
You have an x-pipe.
Old Feb 11, 2008 | 03:55 PM
1.8t's Avatar
1.8t
All LS3's have X-pipes
Old Feb 11, 2008 | 06:15 PM
Corellian Vette's Avatar
Corellian Vette
08s Rocking an X Pipe
Old Feb 11, 2008 | 06:22 PM
RFP's Avatar
RFP
St. Jude Donor '09
Default How 'bout a ZO6?
OK... How about the 2008 ZO6? H-pipe or X-pipe?
Old Feb 11, 2008 | 07:56 PM
Brian@RPT's Avatar
0Brian@RPT
Former Vendor
When I was at the factory, looks is if the Z06 gets the H-Pipe. The H-Pipe on the assembly line was 3" tubing.
To 2008 - "H" or "X" pipe
