oh god!? there aren't too many vettes out there, so I don't think that I can get in to a 2008 too soon, I'll just go for the LS2 if the owner was flexible in the price somehow, and IF I hunt a buyer, then I might rip his pocket off for few thousand $ up and give it up
step by step and I'll jump in a C6 with an LS3 or a ZR-1
Is the LS3 not pretty much just a plain old LS2 with different heads? If so (which I think it is) just buy it and swap the heads out at a later time for around $1200.00..... also, what year did they add the 100,000 powertrain warranty, 06 or 07, dont remember, but either way if you are looking for reliabilty, you will get it with either motor.
Heads are different design and will not swap. The intake and exhaust ports are different. There are many impovements in the LS3: Intake manifold, cam, heads, pistons, rings, rod bolts, thicker bulkheads in the block etc. The LS2 is also a strong engine, but the improvements in the LS3 are worth looking into before you make your decision.
C6 Tech is not the same without Spin
WWSS? (What Would Spin Say)
LS3 head do bolt right in w/ Ls3 intake, TB & any CAI and you will have with-in 15hp of an LS3
There are a number of member already running the ls3 heads and intake manifold on their ls2's. Simply swapping the heads gets you to within 10-15 hp of the ls3.
i'm running a very potent n/a ls2, i beat the snot out of it and drive it everyday to work - hardly a weak motor.
with the difference in price you can build the ls2 to far exceed the stock performance of the ls3. however, if you have the extra money to burn, why not start with the stouter mill?
Don't forget the lowly, 400hp LS2 C6 stomped the 500 hp Ford GT500 in various head to head road tests those first few years...so if that's a weak motor it's one I can live with.
then you are correct that the C6 Corvette was the heads to head winner. However, there was a known issue with early production model GT500’s like the one Car and Driver used that has been well documented and probably was a factor in this side-by-side compare. Numbers-wise, it looks that way.
Ford issues this service bulletin regarding early production cars: “6408 - 2007 SHELBY GT 500 MUSTANG - DRIVABILITY CONCERNS - AIR FILTER
SOME 2007 SHELBY GT 500 VEHICLES BUILT BEFORE 09/01/2006 MAY EXPERIENCE DRIVABILITY CONCERNS INCLUDING: ROUGH IDLE, A SURGE AT LESS THAN 2000 RPM, A LACK OF POWER AND ERRATIC READINGS ON THE BOOST GAUGE. THIS ISSUE MAY OR MAY NOT FLAG A DIAGNOSTIC TROUBLE CODES (DTC) IN THE POWER TRAIN CONTROL MODULE (PCM). THESE SYMPTOMS MAY BE DUE TO A QUALITY ISSUE WITH THE AIR FILTER ELEMENT. TO CORRECT THIS CONCERN, REPLACE THE AIR FILTER ELEMENT WITH PART NUMBER 7R3Z-9601-AA (MOTORCRAFT FA 1807).
I'll just add the the LS2 C6 has bested the GT500 in just about every review. They are neck and neck (a virtual tie) in straight-line accleration but the C6 is the superior track sports car. GT500 wins if you need back seats/room.
Depending of what someone wants (lighter car, less costly ownership, better-all-round performance, technologically more advanced) or (more room, equal acceleration as a LS2 C6, more bolt-on potential, rarity) either car offers alot.
I too was faced with a hard desion a few months back. Do I get a used C5 Z06, a C6 LS2, or weight and order a C6 LS3.
I'm glad I listened to a few trusted friends, and went with the LS3. Why not get the best and newest that's out there at the time!
Here's a bit more on the LS3, good article from Vette Mag...
However, my initial response was the incompatability of swapping LS3 heads into an LS2 motor. Replacing the air intake, intake manifold, exhaust manifolds and heads is more than just a swap. GM engineered the LS3's engine components to compliment each other, such as, increased cam lift and Z06 fuel injectors to feed the LS3 heads. It is not just a head swap, even by exchanging all the needed components for a head swap, is it worth the cost of being within 15 hp?
In your case, I suggest you get the LS2, change later on when you have enough $$$ the center console with LS3 carbon fiber flavor, a Hurricanne air intake (25hp), exhaust+x-pipe (25hp) and never give it a second thought about the LS3.
