A6 tires and sizing??
Old Feb 14, 2008 | 12:05 AM
vetteman24's Avatar
vetteman24
Default A6 tires and sizing??
I have an 08 Z06. I want a tire that i can drag race with. I already have the c6 wheels from my last car so what i'm thinking to save money is to put these A6 tires on the 10'' wheels. I know it will look horrible but it will only be for drag racing. So i've found some different sizes and what is the biggest size i could go to w/ this combo? i found 295/30/19 and 315/40/19..will these 315's fit??? or should i just stick w/ the 295's? and other suggestions?
Old Feb 14, 2008 | 12:09 AM
LS1LT1's Avatar
LS1LT1
Just so ya know, there are no 19" drag radials available. I would go to 18s (or even 17s) for a drag radial set up.
Old Feb 14, 2008 | 12:14 AM
vetteman24's Avatar
vetteman24
The A6's come in 19's... they might not be a drag radial but i'm sure they will hook up just like one... anyone have these?
Old Feb 14, 2008 | 12:19 AM
LS1LT1's Avatar
LS1LT1
I know that.
No, unfortunately they won't. They will very likely be better than stock in most cases though.
Old Feb 14, 2008 | 12:21 AM
vetteman24's Avatar
vetteman24
well then i would like to know if anyone is running these tires and how they hook at the drag strip?
Old Feb 14, 2008 | 12:23 AM
1bdasvt's Avatar
1bdasvt
St. Jude Donor '06-'09
When You say"these tires",what tires do You mean?
LS1LTI is correct that there are NO 19" drag tires!{believe Me,I've checked}
Old Feb 14, 2008 | 12:25 AM
vetteman24's Avatar
vetteman24
i understand that.. how do the A6's hook up at the track?
Old Feb 14, 2008 | 01:26 AM
LS1LT1's Avatar
LS1LT1
From what I've heard from the very few that have tried these (as well as some other stiff sidewall/sticky road racing oriented tires) on the drag strip, they are slightly better than the stock tires but not by that much, their super stiff sidewalls allowed for no cushioning and even caused wheel hop in some instances.
To A6 tires and sizing??
