Template Please
Old Feb 14, 2008 | 08:30 PM
Slick0478's Avatar
Slick0478
Default Template Please
Well As others have posted I got the Vararam and no template
does anyone have one that they can e-mail or fax me please
Or should I just wing it a cut the shroud a little @ time
I called where I bought it from ( forum vendor) and they said there is no template...and really didn't care to look into it for me well while others seem to love this vendor it was my first and LAST order from them...I will say they said they would look into it and call me but the way they said it I'm not holding my breath
Sorry for the rant I have off tomorrow and wanted to install this thing
If anyone can help me out I'de appredciate it
slick0478@aol.com
Craig
Old Feb 14, 2008 | 08:44 PM
LSCHLEM's Avatar
LSCHLEM
St. Jude Donor '08-'09-'10
slick0478@aol.com
Craig
If you give VARARAM a call and explain your situation they will get a template out to you right away. In the meantime I would remove it from the car but dont attempt to cut it on a guess. Some have tried to cut it in the car and punctured the compressor. Much cost afterwards.
VARARAM has great service and will take care of you pronto. Good luck
Leon
Old Feb 14, 2008 | 09:02 PM
Slick0478's Avatar
Slick0478
Also 1 more ? is the filter pre oiled it sure doesn't feel like it
I hope this is going to be worth the headache I see comming
Slick
Old Feb 14, 2008 | 09:08 PM
LSCHLEM's Avatar
LSCHLEM
Default Is The Vr Worth The Headache ?
Slick
The only headache is the impatience and delay. Take your time . Remove the shroud and wait to receive the Template from VARARAM.
You will smile when you drive it after install.
Old Feb 14, 2008 | 10:45 PM
Slick0478's Avatar
Slick0478
I guess your right, I hope they cax fax me one
even if it is in pieces it will get me close and still might be able to install tomorrow if not Sat
Slick
Old Feb 15, 2008 | 05:05 PM
NEV3R L8's Avatar
NEV3R L8
I didn't buy from Vararam itself but I didn't get one either and just kinda guesstimated it. It isn't the BEST install but it serves its purpose and I think looks pretty good and unless you have a very trained eye you wouldn't catch it.
If you want to put it on as bad as I did I'd say go out there and kinda cut a lil off and put the vararam up to it and see how much more needs to come off...
Take your time and I recommend putting either cardboard or a cookie sheet against the coil so you don't cut it or else thats about an $800 fix.
Go HERE for some pictures that will help you decide on your cutting.
Old Feb 15, 2008 | 05:28 PM
VaraRam Industries's Avatar
VaraRam Industries
Supporting Vendor
St. Jude Donor '07-'11-'12
Template mailed today - unable to fax due to size!!!
Old Feb 15, 2008 | 05:55 PM
1954's Avatar
1954
Now that's service!
Old Feb 16, 2008 | 12:56 AM
Slick0478's Avatar
Slick0478
Thanks to all parties
Slick
To Template Please
