Dead Battery in 2008
Well, I just ourchased a 2008 with a 6-speed only three weeks ago and today, after the car only sat for 5 days, I have a completely dead battery!!! I cannot believe that I am going throught this again. I was under the impression that the dead battery system was resolved in models after 2005 but I guess not. Does anyone know of any specific issues with the 2008 with a 6-speed? Are there any quirks or intricasies one needs to know about shutting down the motor to prevent the problem? Any help would be greatly appreciated. Thanks.
(By the way, this just isn't my day as I also just posted a tire monitor problem from today as well.)
I had my battery go dead early on me on my '07 too. Once dead, shame on GM, twice dead, shame on me, and it doesnt take kindly to recharges. My problems got solved by then trashing my oem battery and getting a Optima Yellow Top Deep Discharge for $225. NO problems since, no matter how long it sits. I know the C6 even when shut off draws some battery power. It would not hurt to use a tender, mostly for desuphating, but my Optima does not require it. For sure its needed for the oem battery.
There may be some drain in/on your system. You may want to check that out. Since getting my car in August, during the warm weather I used it almost every day, but did let it sit for at least 5 days. No problem
And then came the 27 day hiatus. No start, no juice, no doors.
Told to buy a battery tender. I did, and now it starts all the time.
and btw, not just buy it, but plug it in and use it.
good luck.
And spearfish above is an example: he let it go for 21 days and it just about started. I let it go for 27 and at first I could get in the door. Then, not at all.
Be advised that I was advised of same in writing from BG. Namely, either take it out and run it to charge it up, or literally, use a battery tender. That was the advice and I have followed it.
Let's put it this way, altho it's not exactly apples to apples. I'd just as soon go out there every time and put a key in the door and then in the ignition. I can't do that. I need to use the fob. Part of the car, and that's the way it is. Maybe the logic is faulty on my part, but that's how I'm choosing to look at it.
Your case, and five days does really seem a little short even tho you're in the cold clime and that makes a battery lose a lot, quickly. I would take it in and have someone check for drain. I have seen one driver error (and I've done it): hit the little button for dimmer switch and it can leave lights on. Also, hit one of the buttons under the mirror and it can leave one of those lights on for awhile.
-- As I have said, before, this really bugs me. When warm weather comes, I plan to discontinue use of my "battery tender", and if the DBS continues, GM and I are in for some interesting times. -- Good luck, with your problem. --
I used the tender in the 05, I let the wires run under the gently lowered, but not locked hood. The tender itself sat on a crate.
I ALWAYS hook up direct to the battery, I like the shortest route possible.
Even with the Z I hook up to battery in trunk and let the wires come out the hatch Secure garage
Dave.
Yes, I leave it on all the time.
And to McWire's post: yes, I'll probably discontinue using it come the good weather, too. That is, as long as I know I'm going to be using the car fairly constantly.
Personally, I think most of the damage to the batteries is done while sitting at the dealerships. The cars sit and drain. When it's time for a test drive, they put a quick charge on it and then allow it to die again. How many deep cycles and quick charges do they think a battery will take? They're probably the cheapest batteries they can find to begin with.
On one hand I feel, if the car requires a battery tender, they should be required to deliver one with the car. On the other hand I'm glad I didn't have to pay for a GM tender with a Corvette tax instead of the $19.95 I paid for a DieHard tender.
If you want peace of mind do to no way to use tender, get a priority start for your car.
If you have to leave it for extended periods then the batter tender is the way to go.
I also have the mild to wild exhaust switch which as of today is now wired for zero drain... which is wasn't before.. maybe this will help..
