SCS: More powerful alternator?
Old Feb 18, 2008 | 11:47 AM
NavyC4S's Avatar
NavyC4S
St. Jude Donor '09
Default SCS: More powerful alternator?
I've been having the service charging system error code for quite some time now and it may be due to the underdrive pulley underdriving the alternator. This is one of many conclusions, but seems possible because the battery charges just fine when I give the engine a 200 RPM rev and I don't get the error message when driving.
There is an overdrive pully availible for the alternator, but it seems to be half the size and I'm concerned about overdriving the alternator to the point that it fails.
Is there an aftermarket generator availible that will charge at lower RPMs?
Old Feb 18, 2008 | 12:18 PM
Miaugi's Avatar
Miaugi
Look in the yellow pages for a shop that rebuilds altenators, I'm sure they can do something custom for you....at a cost of course.
Old Feb 18, 2008 | 03:40 PM
NavyC4S's Avatar
NavyC4S
St. Jude Donor '09
there is always a cost...ugh.
Old Feb 19, 2008 | 11:58 AM
andreas g.'s Avatar
andreas g.
No rebuilds, factory part only. About $550 unless you get a jobber discount, then about $285. Not cheap.
Old Feb 19, 2008 | 05:34 PM
NavyC4S's Avatar
NavyC4S
St. Jude Donor '09
I'm pretty sure mine works fine, it just doesnt spin fast enough at idle. I'll just go for the pulley.
Old Feb 19, 2008 | 06:36 PM
sea six's Avatar
sea six
Which pulley did you use? I am thinking about changing mine! Did you install it your self?
Old Feb 19, 2008 | 08:01 PM
Ragtop 99's Avatar
Ragtop 99
Why not raise your idle 50 - 100 rpm?
Old Feb 19, 2008 | 08:05 PM
dennis50nj's Avatar
dennis50nj
i would try that first
Old Feb 20, 2008 | 04:14 PM
NavyC4S's Avatar
NavyC4S
St. Jude Donor '09
I suppose I could do that to see if it actually works.
To SCS: More powerful alternator?
