Battery Tender
Old Feb 19, 2008 | 09:57 AM
Dffej51's Avatar
Dffej51
Default Battery Tender
OK, I have finally come to the conclusion after reading all the input on the forum that living in the Northeast where good days to drive the Vette are sparse I must break down and use a battery tender (trickle charger) on my 2008. I know quite a few of you have experience with these and I would appreciate a recommendation as to how many amps a good battery tender should put out. Thanks to all for your help.
Old Feb 19, 2008 | 10:09 AM
SvetteC6's Avatar
SvetteC6
I have the CTEC 3300 and I'm very happy with it. The amperage varies depending on the state of the battery.
Old Feb 19, 2008 | 10:12 AM
Larry R's Avatar
Larry R
FWIW, I purchased a Battery Minder. Cost is about $40 to $45. It will desulphate as well. Specs are: Input: 120 vac
Output: 12 volts @1.0 amps
Charge voltage: 14 Vdc
Float voltage: 13.4 Vdc
Desulphation pulse: 1.0A @ 3.26Mhz
Float current: 5mA-200mA
You can do a Google search to find the best deal. Hope this helps. I forgot to add model, number is 12117, for Battery Minder Plus.
Old Feb 19, 2008 | 10:14 AM
AORoads's Avatar
AORoads
St. Jude Donor '15
"In honor of jpee"
I'd agree with both of the above and also suggest your local auto parts store/chain where you can find a Schumacher battery tender at the $20-$25 level.
And note: it really isn't a trickle charger; it is a battery tender which is ostensibly different.
Old Feb 19, 2008 | 10:03 PM
Miaugi's Avatar
Miaugi
...plus I also have the 800 model!
Old Feb 19, 2008 | 11:46 PM
C5pilot's Avatar
C5pilot
I have the DieHard battery tender, $19.95 on sale at any Sears/Kmart. This is the first winter with it but it seems to be working perfectly.
Old Feb 19, 2008 | 11:59 PM
cfp40's Avatar
cfp40
I have the CTEK 7000. Its a pulse charger and only sends a charge when the battery voltage falls below 12.9 volts. The charger measures the voltage every 10 minutes and does not send a charge to the battery unless it needs it.
CTEK 7000 Charger
Positive Terminal Connection
Negative (ground) Connection
Negative (ground) Close Up
Old Feb 20, 2008 | 01:50 AM
Thrasherman's Avatar
Thrasherman
Great Product, I have 3 of them on different toys, no problems.
Old Feb 20, 2008 | 02:04 PM
sscamaro's Avatar
sscamaro
St. Jude Donor '07
I use Battery Tender Jr. About $20 ea.
To Battery Tender
