2008 Emergency Brake
Old Feb 20, 2008 | 09:11 AM
George De's Avatar
George De
Default 2008 Emergency Brake
My new 2008 coupe (100 miles) emergency brake squeals (sounds like metal on metal) when I apply if I am moving the slightest bit forward--anybody notice same problem. No squeal if going backward.
Realize it is only supposed to be used when parking but the squeal sound like metal on metal--any ideas?
thnx
Old Feb 20, 2008 | 09:16 AM
Miaugi's Avatar
Miaugi
I would have to guess it's because the pads aren't worn in yet. Take it out and apply it a couple of times at 30 mph, not more than 3 times though as you don't want to overheat them.
Worse case scenario you are right but either way it will be covered under warranty.
Old Feb 20, 2008 | 09:38 AM
Zippy's Avatar
Zippy
Cruise-In 2, 9 & 10 Veteran
St Jude donor '09
I'd let my dealer look at it...warranty covers any cost to you.
Old Feb 20, 2008 | 11:50 AM
overrev64's Avatar
overrev64
DO NOT DO THIS! The brake pads have nothing to do with the parking brake. The parking brake on the Corvette has small brake shoes within the hub area of the rear rotors. They have very little lining thickness so the above-mentioned procedure could wear them out immediately.
Have the dealer check on the noise.
Old Feb 20, 2008 | 12:28 PM
BobST1100's Avatar
BobST1100
Hard to say with only a hundred miles. I don't like dealers touching my car so depending on how comfortable you are working on your car, you might want to pull the rotors and inspect the emergency brake shoes. You may find you've picked up some debris. Otherwise let the dealer check it out...with you there if you can!
I wouldn’t take it up to speed and try to wear them in..
Old Feb 20, 2008 | 12:53 PM
Miaugi's Avatar
Miaugi
I can understand your contrary opinion on this but this it what I would do.
First of all I hate taking my car into the dealer, most don't do a very thorough job plus it is usually not convenient to bring in my car into them and it's not like we get special treatment.
Secondly it is called an "emergency brake" and I think you may be over reacting on how fragile this system is, but that's my opinion and you have yours....freedom of choice is a great thing!
Old Feb 20, 2008 | 02:48 PM
overrev64's Avatar
overrev64
According to the owner's manual, it is called the Parking Brake not the Emergency Brake. Emergency Brake is an old term that was used on cars with single reservoir brake systems that would fail if a leak occurred. It usually consisted of a mechanical means to apply the rear service (Hydraulic) brake in an emergency condition as well as prevent the car from rolling while parked.
The Parking Brake on the Corvette is not designed to stop the car and if you ever examined one, I think you would agree that it would not hold up to application at speed.
Old Feb 21, 2008 | 07:26 PM
calemasters's Avatar
calemasters
thnx
Normal. Only apply when stationary.
Old Feb 22, 2008 | 08:29 AM
foremaw's Avatar
foremaw
Active Streak: 90 Days
St. Jude Donor '08-'09-'10-'11-'12
To 2008 Emergency Brake
