Suggestions on launching....
I recorded this with my driftbox yesterday. The 60' sucks. Any suggestions on launching with the runflats.
These times recorded from non prepared concrete surface.
Accel results
Speed(mph) Time(s)
0-60 04.5
0-100 09.1
Accel Distance results
Distance() Time(s) @Speed(mph)
0-60' 02.6 34.3
0-330' 05.9 73.2
0-660' 08.5 96.0
0-1320' 12.7 120.2
Accel results
Speed(mph) Time(s)
0-60 04.5
0-100 09.1
0-60' 02.6 34.3
0-330' 05.9 73.2
0-660' 08.5 96.0
0-1320' 12.7 120.2
Accel results
Speed(mph) Time(s)
0-60 04.5
0-100 09.1
0-60' 02.6 34.3
0-330' 05.9 73.2
0-660' 08.5 96.0
0-1320' 12.7 120.2
Accel results
Speed(mph) Time(s)
0-60 04.5
0-100 09.1
0-60' 02.6 34.3
0-330' 05.9 73.2
0-660' 08.5 96.0
0-1320' 12.7 120.2
WOW, THOSE NUMBERS ARE WAAAY OFF OF REALITY
How would you know?
Its impossible for a C6 on the street to run
60' 02.6
330' 05.9
660' 08.5
1320' 12.7 at 120
Remember the track does not record terminal MPH but the avg of the last 60' so it is always 2-4mph slower, with that poor of a 60' the mph could be that high.
60' 02.6
330' 05.9
660' 08.5
1320' 12.7 at 120
How would you know?
60' 02.6
330' 05.9
660' 08.5
1320' 12.7 at 120
60' 02.6
330' 05.9
660' 08.5
1320' 12.7 at 120
NO BUT WITH A 2.6 60 A D 12.7 IS IMPOSSIBLE TO RUN UNLESS YOU HAVE A TON OF MODS. WHAT KIND OF MODIFICATIONS DO YOU HAVE?
Right now the best advice is to just give it less gas.
How would you know?
60' 02.6
330' 05.9
660' 08.5
1320' 12.7 at 120
60' 02.6
330' 05.9
660' 08.5
1320' 12.7 at 120
25psi and 3 secodn WOT "burnout" and launching at 50% throttle and rolling into full throttle about 30 feet out gives me consistant 1.9 60's on the base runflats.
Good luck...good times come with practice
I'm interested to see the comparisons also.
Ok the 30 feet is an approximation, lol...it may be 15-20...but my point is wait until you are moving so that when you stomp it you dont put em up in smoke, lol.
Just try all sorts of ways and you will eventually figure out what works best for you...all cars WILL react differently to a degree.
I get slightly better 60' by easing into it like you, but get better ET's by stomping it fully from the get-go. I wont be worrying about it as much anymore, cuz got myself some DR's
Get to a real track and get real times. Theres no way to tell you how to improve because we can't know conditions or accuracy.
I thought the conclusion was that that wasnt the case anymore in the other thread talking about that?
Did nhra change all the tracks timming systems?
TC off and AH on for drag strip. TC was designed to maximize safety not max launch speed.
www.rangeracceleration.com is a great resource.
I launch from 4500 rpm to 5300 rpm depending upon track conditions, walking out the clutch and attempting to keep the revs the same (no bog) until I feel traction then going WOT as fast as possible without causing wheelspin.
It takes practice.
I wouldn't even bother with runflats, get some drag radials. You wouldn't go bowling in baseball cleats - the proper shoes increase the satisfaction of the event dramatically.
It takes practice.
[QUOTE=Joe_G;1564242820I wouldn't even bother with runflats, get some drag radials. You wouldn't go bowling in baseball cleats - the proper shoes increase the satisfaction of the event dramatically.[/QUOTE]
True...though Evilways sure seems to gets a lot of pleasure out of his at burnouts on runflats!
