Check Engine Light
Old Feb 24, 2008 | 05:52 PM
tloon's Avatar
tloon
Default Check Engine Light
Started the car today after 3 months in storage. Recently installed new Callaway plug wires. Check engine light was flashing. Discovered that somehow one of the upper coil wires had become disconnected. After replacement, light stopped blinking, but is still on. Will the light reset itself? Do I need to have it shut off with a diagnostic tool?
Old Feb 24, 2008 | 05:54 PM
achilds's Avatar
achilds
It should eventually reset itself after a number of starts if the problem is truely fixed. You can get a scanner for less than 50 bucks if you just want to reset it.
Old Feb 24, 2008 | 05:57 PM
timd38's Avatar
timd38
That's what I would do.
Old Feb 24, 2008 | 06:07 PM
tloon's Avatar
tloon
Can anyone recommend a good scanner to buy?
Old Feb 24, 2008 | 06:08 PM
timd38's Avatar
timd38
I have an Actron. Sears and AutoZone sell them.
Old Feb 24, 2008 | 06:42 PM
achilds's Avatar
achilds
I have a small Actron also. I got mine at Kragen.
Old Feb 24, 2008 | 07:57 PM
LSCHLEM's Avatar
LSCHLEM
St. Jude Donor '08-'09-'10
IFYOU GET A SCANNER JUST MAKE SURE IT IS obd2 /can cmpliant. a GOOD INVESTMENT.
Old Feb 25, 2008 | 07:39 PM
tloon's Avatar
tloon
Update:
Light went off after the third cold start. May still go for the scan tool though.
Old Feb 25, 2008 | 09:20 PM
johnodrake's Avatar
johnodrake
Moderator
Update:
Scanner is a good investment.
Old Feb 25, 2008 | 09:37 PM
DJackman's Avatar
DJackman
If all you want is to clear the CEL, just unplug the battery for 10 minutes and it will clear up. But if you want a scanner just to have one, here's a basic one for 80 bucks
http://www.amazon.com/enabled-Reader...3993323&sr=8-4
To Check Engine Light
