If there's one thing I hate about my C6, it's the bloody driveline sloppiness. At slow speeds, when crawling along in 1st, any change in throttle position usually results in the car 'kangaroo'ing' and is often accompanied by the diff clunking like someone has hit the housing with a damn hammer. It's a constant battle to work-around this is stop/go traffic by slipping the clutch and/or avoiding 1st gear. Additionally, I've noticed, when cold, the 2-3 shift borderline grates/crashes going into 3rd. It's not audible, but I can feel it through the shifter.
So, is a diff/trans oil change likely to improve the above issues? If so, should I stick with the OE oil, or go aftermarket? Bear in mind the car is a daily-driver and the oil must be able to copy with ambient temps from ~25f to ~95f.
You must drive really slow. I've owned more 6 speed GM cars than underwear and have never noticed it.
Only when traffic dictates that I HAVE to, ie. In stop/start traffic when crawling along in 1st.
Originally Posted by Michrider
If there were no play in driveline parts, they wouldn't last more than a day. A ring an pinion with no backlash wouldn't make it around the block.
I've driven manual transmission cars all my life (various makes) and I don't think I've ever experienced driveline shunt quite as bad as the C6. Some stick shifts suffer from it to a minor extent, but plenty don't suffer from it at all. May not be a fair example, but my Ferrari 355 never had any driveline 'slack' issues at all.
A good synthetic like Amsoil ATF in the trans will help the cold shift feel a bit, I'd definately do that.
I may well try new trans oil... what is the exact spec Amsoil I should get? Redline trans oil a fair alternative? Whatever oil goes in, it must not be worse than stock under any conditions! Have read horror stories of people using RP Synchromax in cold climes!
Any synthetic that has the same Dex spec. The stuff Amsoil has that meets the spec and I've used many times with good results is just called Amsoil ATF. It meets the GM Dex spec.
Cheers,
Ian.
It's a car not a swiss watch, get over it. So it makes some noise and clunks. It will not negatively effect performance.
I certainly understand where u are coming from. I've always said that if I had to drive in rush hour traffic that I would get an automatic. I would definitely go with the Amsoil in the diff and trans. Makes a big difference in smoothing out shifts. Lastly, I would recommend the MGW shifter. While it won't help with driveline sloppiness it will definitely give you a much better feel when you shift gears. Makes the stock shifter look wimpy in comparison.
Would appreciate anyone using the link that Michrider pasted above to buy AMSOIL (which bypasses the tagged forum vendor link to the left) use the reference number in my signature to ensure the sale is credited to my dealership and helps benefit the forum. Thanks.
In amplification of the original question on AMSOIL fluid applications:
I've been using the former in my 02 Z06 tranny for track duty for years without failure and added it to my 06 CTS-V (same tranny) last fall.
The ATD has a slightly higher viscosity and I'm considering switching to it in my Z06 this season. Either is really fine for the C6 manual transmission. The ATF is also suitable for Dexron VI and thus the C6 automatic transmission as well.
Been using the SVG in my 02 Z06 diff on the track for years, again without issue or diff failure (other than the common C5 left axle seal leak) and added it to my 06 CTS-V last fall.
