New exhaust
Old Feb 26, 2008 | 02:13 PM
Matthdj's Avatar
Matthdj
Default New exhaust
I had a new exhaust put on my 07 vette, headers, x-pipe, and corsa mufflers. After installation I had a leak where the headers tied into the x-pipe so I took it back and they put grafoil tape under the clamps. When I questioned them about this they said it is a common practice and that it is not a band aid to fix the problem. What I want to know is, is this a common practice?
Old Feb 27, 2008 | 01:29 AM
HuskerBullet's Avatar
HuskerBullet
Ppppfffftttt! Sounds like a load of crap. The pipes don't match up to seal, so they need to be adjusted (re-bent). So the special masking tape they are using on your $50,000 machine will not burn through after a few hundred miles at 1,000+ degrees? Hmmm, must be a space-age product used to keep the shuttle from burning up when re-entering the atomsphere...it's probably ok.
Old Feb 27, 2008 | 02:23 AM
Gold Z's Avatar
Gold Z
Veteran: Marine Corps
Actually that is a common thing to do. It's cheap and it works.
To New exhaust
