Corsa exhaust
Old Feb 27, 2008 | 03:54 PM
Z06Norway's Avatar
Z06Norway
Default Corsa exhaust
Hi guys i have a Corsa touring system for C6 A6, i understand they changed the midsection as the M6 and A4 is the same.
So a std. A4 and M6 will not fit an A6 car, but what about the other way around ?
Will a A6 system fit an M6 car
TIA
Rune
Old Feb 28, 2008 | 12:21 AM
velocity yellow 2006's Avatar
You can use what you have on your car. The A6 kit
(14167) uses a special mid pipe (resonator section) to remove the drone that comes with the A6 gear ratio. You can also use the factory mid pipe if you like.
Old Feb 28, 2008 | 05:45 PM
Z06Norway's Avatar
Z06Norway
Update, you can use it, BUT you have to move one of the attachments on the mid section.
Rune
To Corsa exhaust
