active handling scare
Found it:
TSB 06.02.35.002
Diagnostic Trouble Code (DTC) C0710 Steering Wheel Position Sensor (SWPS) Signal, Service Stability System Message on Driver Information Center (DIC) (Inspect and Secure Wires in SWPS Connector)
2005-2006 Chevrolet Corvette
with Steering Wheel - Tilt, Telescoping (RPO N37)
Condition
Some customers may comment on a Service Stability Message on the DIC.
Diagnosis with a scan tool may reveal a DTC C0710.
Cause
The most likely cause of a DTC C0710 on a vehicle equipped with telescoping/tilt steering wheel is high resistance in SWPS connector C202. Fretting terminal corrosion maybe present in the SWPS connector due to the telescoping motion of the steering column. When the steering column is telescoped in and out, the female terminals within the SWPS connector may move on the male terminals of the SWPS. This movement between the terminals may cause a high resistance condition in the SWPS connector.
Correction
Remove the driver's side close out panel.
Notice:
• Failure to properly tape the wires in the connector may result in additional concerns.
• Failure to use a small plastic strap 2.5-3.5 mm (0.10-0.14 in) in width may prevent the SWPS connector from properly seating, resulting in additional SWPS DTCs.
Using electrical tape (1), tape from the plastic strap up the wires a minimum of 2.5 cm (1 in).
Install a small plastic strap (2) 2.5-3.5 mm (0.10-0.14 in) wide around the SWPS sensor connector so that it retains the wires to the connector as shown.
Important: Install and remove the SWPS connector a minimum of three times to remove any possible terminal corrosion.
Reinstall the SWPS connector.
Reinstall the close out panel.
http://forums.corvetteforum.com/show....php?t=1429960
Found it:
TSB 06.02.35.002
Condition
Cause
Correction
Notice:
I was assuming it was the smaller one on the sensor itself, but in another thread I was reading, they mentioned the larger one. Also, what do I tape and zip tie (plastic strap?)? Thanks.
Joe
Not sure if it still works this way but many moons ago I had an electrical problem with my Pontiac Fiero. I complained but the problem always went away when I got to the dealer. They logged it in their system, but said they could not fix something they could not verify. The problem eventually became solid AFTER my warranty expired. They fixed it and did not charge me because it was logged as a problem during the warranty period. (The speedo needle and tac would point straight down and not indicate anything useful at all).
So - if the dealer knows there is some problem but can't identify the real source of the problem during the warranty, you might still be able to get it fixed after warranty expires.
I have also had (have?) the traction control error. For me it was occasionally accompanied by ABS failure and even some times the gas gauge will read empty. 'Rebooting' the car usually brings it back to life. Does this car have any Microsoft blood in it? They have yet to find the cause of the problem. 3rd time in for this. They have the logs of the many events, I even drove with a logging device in the car for a while. It did not help them track down the issue. Next time I will bring in the service bulletin and see if they have already performed that fix.
