Vara. SC1 Snake Charmer installation help!
Old Feb 29, 2008 | 11:19 PM
ngo449's Avatar
ngo449
Default Vara. SC1 Snake Charmer installation help!
Hi, Everyone
First off, I would like to thank all of you recommending the Vararam SC1cold air intake. I am very new to this forum. I have a 2007 C6 & just bought the Vararam SC1. I am not very mechanically incline. I have not the slightest idea how to install this unit. If any one has step by step instruction, pictures with instructions, or taken pictures of their Vette while installing the unit, please help. Or if anyone know of a good shop in the dallas/fort worth area, let me know. Thanks in advance for all those who reply. Thanh.
Old Mar 1, 2008 | 08:30 AM
VaraRam Industries's Avatar
VaraRam Industries
Supporting Vendor
St. Jude Donor '07-'11-'12
Originally Posted by ngo449
Hi, Everyone
Go to our website and find the product page for the VR-SC1. Near the bottom is a link for the instructions, Also if you search this forum for the write up done by "Shocker Racing" on the install -it is excellent help. If you still need more info call our tech line - 713-899-6456 - for help! LG Motorsports in Wylie is an excellent shop if you are looking for someone to do the install and other work. Tell Bobby - Steve from Vararam sent ya!!
Steve
Old Mar 1, 2008 | 09:07 AM
NEV3R L8's Avatar
NEV3R L8
...or VETTE's guide
Old Mar 28, 2008 | 07:05 PM
XvettemanX's Avatar
XvettemanX
Steve
doesnt sound good to me when vararam industries themselves tell us to refer to write ups in the forum to assist with installing their product...shouldn't THEY provide adequate instructions?
Old Mar 28, 2008 | 07:08 PM
El Dorado's Avatar
El Dorado
St. Jude Donor '08
But they do provide instructions....... IMHO P1SS POOR ones. My ready to eat cereal has better instructions!
Old Mar 28, 2008 | 07:18 PM
XvettemanX's Avatar
XvettemanX
like i said, shouldnt they provide ADEQUATE instructions
Old Mar 28, 2008 | 07:37 PM
Nd4spd2's Avatar
Nd4spd2
St. Jude Donor '08
I'm considering ordering a Vararam as well so I'm marking this thread for the instructions just in case.
Old Mar 28, 2008 | 09:26 PM
HorsePower Junkie's Avatar
HorsePower Junkie
St. Jude Donor '20-'21-'22-'23
..."search this forum for the write up done by "Shocker Racing" on the install - it is excellent help...
Steve,
How about a link to the forum write up you mentioned please...
Here's a link to Vararam's website instructions: http://www.vararam.com/C6-snakecharmer.pdf
Old Mar 29, 2008 | 08:49 AM
VaraRam Industries
Supporting Vendor
I have the link saved on the computer at work and will try to remember on Monday to post it here!!!
Steve
Old Mar 29, 2008 | 09:29 AM
08 Vett's Avatar
08 Vett
Here's something I did on my car that makes it a better fit.
On the radiator cover, I milled a 3” by 4” pocket thru the top to allow the tube from the CAI kit to fit without hitting the hood. I also gives it a straight shot to the throttle body.
The cover removes with 4 bolts, took my 10 minutes to mill the pocket.
Sorry, I should have taken Pics before I put it back together.
Old Mar 29, 2008 | 09:44 AM
dennis50nj's Avatar
dennis50nj
Steve
heres the link it doesnt work anymore
http://www.shockerracing.com/phpBB2/...pic.php?t=1789
Old Mar 29, 2008 | 09:53 AM
LSCHLEM's Avatar
LSCHLEM
St. Jude Donor '08-'09-'10
First of all if you are a new member I would like to welcome you to CF.
Our folks here are nothing short of the best. You can find anything about your corvette here.
Now on the subject of the VR install its not so bad. The one thing that causes the most problems is the shroud. There are varying opinions on this and many threads. Here is what I would do.
1. Do not try to cut the shroud in the car. Remove it, there is a bunch of buttons & screws to be taken off but thats the best way to go.
2. When you have the shroud out use the template and remember that
the template wraps around the bottom and thats where you cut. When done the shroud will have a u shape with the bottom open. When you put it back in you will find that it still doesnt fit remove more shroud material until the vr filter box has about 1/2 " clearance on each side. Some have tried to cut the shroud in the car and some have punctured the condensor coil (radiator ) Its a matter of choice and mechanical abilities. What I descrived is the most conservative way.
The rest is very easy. Good luck, Leon
Old Mar 30, 2008 | 09:55 AM
08 Vett's Avatar
08 Vett
I slid a 1/8" sheet of Lexan behind the shroud before I cut it.
That way if I did slip up, I'd hit the Lexan doing NO damage to the radiator. It worked out well and I didn't spend a lot of time removing the shroud.
To Vara. SC1 Snake Charmer installation help!
