z51 Supercar Tires
Old Mar 2, 2008 | 07:38 PM
bunzaroo's Avatar
bunzaroo
Default Switching Tires / Help!!
I am planning on running either BFG KDW 275 35 18 / 295 35 19 or Bridgestone RE050a 275 35 18 / 305 30 19 on 18/9.5 X 19 /11 How do these 2 tires differ from the z51 GY supercar Runflats that my car has now in both handling / comfort. Thanks
Old Mar 4, 2008 | 11:33 AM
vettl83's Avatar
vettl83
I've done some research on the tires you mentioned. The stock Goodyear Super Car tires have a treadwear rating of 220. The Bridgestones are at 140 for treadwear rating and if you switch the aspect ratio to 30 vs 35 in the rear you need to recalibrate the speedo.
The BFG's have a treadwear rating of 300. The Bridgestones should give you the best dry traction due to the soft treadwear rating and the
BFG's should live longer. They both should ride better than the run flats.
Good luck with your decision.
Old Mar 4, 2008 | 11:38 AM
FloydSummerOf68's Avatar
FloydSummerOf68
I wouldnt run the 305/30/19 tire...it'll look too small.
Old Mar 4, 2008 | 04:19 PM
andreas g.'s Avatar
andreas g.
305/30/19's are 26.3 in dia, and the 285/35/19's are 26.9 in dia. You're losing over 1/2" tire dia. They look short I've seen them. At least you'ed have to lower your car 1/2 inch all the way around. Then you chances of hitting more is greatly increased. It's all a matter of taste. And yes your speedo would be off somewhat. If your looking for tires the Firestone RFT are made for C6's in stock sizes. Also kumho makes tires in a non runflat. Both are excellent tires. I've got the firestones. They run great, no noise handle very well, and are $1034 out the door vs goodyears at $1900.
To z51 Supercar Tires
